front drop on H&R sports WAY too low
  • LJ851
    • 7919
    #46
    Originally posted by taiden
    I'll probably get some shorter inserts next time around. The amount of travel I have now is unacceptable.
    My thoughts exactly.
    Lorin
    The M30 is God's engine.
    • taiden
      • Oct 2009
      • 178
      #47
      Also, for what it's worth:
      • CW325
        • Jul 2011
        • 1434
        #48
        ^^ looks like a normal drop to me
        • BMWerke
          • 893
          #49
          i am on h&r sports and i think they are too soft and the drop is mediocre at best. but that looks fine to me
          '90 325is DD, 5 spd swap-H&R springs-Euro Headlight Fully Built OBD1 M54b30. Ox Blood interior, 3.46 LSD with Z3M Diff Cover. Custom shifter, every bushing replaced.
          '86 325e- Donor car for swap/parts car
          '00 323i- BBS 197s Totalted
          '89 740 turbo Volvo- Donated
          • Jean
            • 18228
            #50
            They are craptastic springs anyways.
            • Ryann
              • 3350
              #51
              If those are 205/60/14's that is essentially the identical drop that I experienced with my 29664's, although I think my car is slightly heavier.
              • Holland
                • Nov 2008
                • 7212
                #52
                Your tires look large, but it does sit really nice. You mention that you have boge's in the front? It's possible they are too soft of a rate for those springs. The recommended combination is Bilstein sport struts, although I personally think they are a little too over valved for sport springs.
                Originally posted by DEV0 E30
                • taiden
                  • Oct 2009
                  • 178
                  #53
                  I agree with you all, the sport springs are too soft. They are certainly an improvement, but definitely too soft.
                  • moatilliatta
                    • 6158
                    #54
                    Originally posted by ak-
                    An m10 weighs 83kg/180lbs
                    An m50 weighs 140kg/308lbs
                    Daz long block weights ;)
                    But still the difference is relevant.
                    Buddy had an 86 eta and the drop was similar. I agree its more than normal sports that you regularly see. Could be different production runs? I recon the race spring has 2 different production runs with even different spring rates if my memory serves me right.
                    @Zakspeed_US
                    • smooth
                      • Apr 2005
                      • 1940
                      #55
                      I just went out and measured my H&R's w/ Bilsteins and it looks like I have
                      13.5" from center to fender in the front
                      13" from center to fender in the back
                      ~6" from ground to rocker panel in the front
                      ~8" from ground to rocket panel in the rear
                      the way mine sits in the back has always annoyed me. I finally ripped out the soft top and that helped but when I put the tonneau cover back on it went back to looking slightly droopy in the rear.
                      Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
                      • LJ851
                        • 7919
                        #56
                        Some simple spacers or extra spring pads in the rear will fix that right up.
                        Lorin
                        • smooth
                          • Apr 2005
                          • 1940
                          #57
                          I can't remember what I did ten years ago but I had to buy the springs new because I couldn't find anyone selling cabrio springs and I bet I bought new spring pads. If there was an option or a write-up about using thicker pads I likely followed that. Any links to help me do what you're suggesting?
                          Sorry for hijacking the thread but another issue has always annoyed me too and that's when I get out of the car the rear creaks. I can rarely replicate it by bouncing the driver's rear around but not as drastically. Anyone have any ideas where to start looking?
                          • LJ851
                            • 7919
                            #58
                            Yes.
                            Lorin
                            • smooth
                              • Apr 2005
                              • 1940
                              #59
                              Thank you.
                              • Exodus_2pt0
                                • 5943
                                #60
                                That is a perfect drop for a street car IMO. Looks tasteful.
                                No E30 Club
