This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #391
    Originally posted by rennegade
    Ok, well I have found out that they have actually been redrilled as they were 4x114 before if that changes anything. And the rears are actually 9.5" wide. Another question though, would it be better to pull or roll the fenders? pulling would look better but doesnt it stress the paint and cause it to crack etc?
    thanks Luke
    Well you'll need to get the offsets, as it could be anything at this point.
    With 9.5" wide rears, rolling is very likely not going to be enough clearance and you will have to get into pullling/bodywork. Unless the offset is a little higher and the wheel sits close to the struts (a rare setup), you're looking at some good work back there.
    Jay
    • rennegade
      • Oct 2007
      • 50
      #392
      And also how much stretch would there be with 205/40/16 on 8" and 215/40/16 on a 9.5"
      • viali8
        • Nov 2005
        • 673
        #393
        cool
        Originally posted by Mystikal
        Yeah, it would be to the nearest half an inch. Either 15x6 or 15x6.5 ET32 will bolt right up without issue.
        Jay
        thanks for your help!
        • moatilliatta
          • 6119
          #394
          how well are the Potenza RE960AS Pole Position? 205's on an 8 inch wheel.
          @Zakspeed_US
          • Mystikal
            • 9602
            #395
            A very noticeable stretch on the 8", and a borderline extreme one on the 9.5". Think rim sticking outside of the tire on both sides.
            Jay
            • Mystikal
              • 9602
              #396
              Surprisingly...not the greatest. They are fairly competitive, but there are other, cheaper entries that are actually more capable. The super-cheap Falken ZE-912 is currently the highest rated all-season tire, although if I remember correctly for your use you're looking for a snow-capable tire. The only all-seasons that like snow are the Continental Contiextreme, the Nokian WR, and the Sumitomo HTR+. For your purposes either get one of those or a performance winter.
              Jay
              • moatilliatta
                • 6119
                #397
                how well are the wr's on dry pavement?
                @Zakspeed_US
                • Mystikal
                  • 9602
                  #398
                  More capable than most winter tires, but still a lot softer in response than a true summer tire. Braking distances will also suffer.
                  There's really no way to have your cake and it too with one tire. But you can get pretty close with these new tires.
                  Jay
                  • rennegade
                    • Oct 2007
                    • 50
                    #399
                    Jay
                    Ok well Ive got the wheels here in my room. The guy I bought them off had them on his M30 turbo E30 and he didnt roll his guards at all. How would I find out the new offset? And .5" really make that much difference? as with 9s rolling is generally enough.
                    • moatilliatta
                      • 6119
                      #400
                      I like these a lot. But they dont have a friendly size I need..
                      205/65/15? not great but i need a tire to fit a 15x8 on a lowered ix. This profile will is 1.5 inch bigger. and will make my car set up .75inch. but with some streach it may lower it some... i dunno. as is i think it sets to high up..
                      195/65/15?? still oversize but not wide enough..
                      @Zakspeed_US
                      • Mystikal
                        • 9602
                        #401
                        As I said, it's all about offset. If those rear wheels hug the inside of the car, then yeah with 215 tires you can get away with it. So if you have his experience and don't have the final offset...there's not much I can tell you here.
                        To find out the offset you can read the original model on the wheel (RSxxx) and look up the specs of that wheel stock, then use that data to figure out the new offset (I can do this for you).
                        Jay
                        • Mystikal
                          • 9602
                          #402
                          http://www.nokiantires.com/en/tire_w...?season=winter
                          Neither of the sizes you mentioned will work on an E30. 195/60/15 will, and will mount on your wheels...but of course it will be stretched quite a bit.
                          For your purposes, the best tire is the 205/55/15 Continental ContiExtremeContact. If it shows my enthusiasm for this tire as a good dry/wet and occasional heavy snow tire, I just ordered a set for my M3.
                          Jay
                          • moatilliatta
                            • 6119
                            #403
                            i always thought continental was garbage...
                            Never owned their tires though...
                            Just shop stories.
                            EDIT: I don't see discount doing a 100 of a set of tires? did the stop that? If you called and asked do you guys think they would do it?
                            @Zakspeed_US
                            • Mystikal
                              • 9602
                              #404
                              Just shop stories.
                              Continental is a huge hit-or-miss company. Most of their OEM stuff is only okay, but some of their models (SportContact2 and 3, ContiExtremeContact) are excellent.
                              The Discount, um, discount ended on the 20th of Oct IIRC. Tirerack has better prices for that tire anyways last time I looked.
                              Jay
                              • rennegade
                                • Oct 2007
                                • 50
                                #405
                                Jay
                                Ok so where would I find the RSxxx code? I have looked behind the center cap and think that mayeb the redrilled fitment may have destroyed it? Anything else that could help you?
