This is a sticky topic.
    Originally posted by Mystikal View Post
    Those wheels are suitable for the plebeian E36 5-lug swap crew. You have something more, something that they would kill for. You can run much, much lower offset (see: dish or concavity) wheels from 5/6/7/8 series cars, literally thousands of gorgeous low-offset choices to pick from. Put the 16" +40s down and buy something worthy of your hubs.
    dude......... do not say that.
    these
    on this
      hey guys i'm trying to figure out my setup for my e30....its going to have bilstein b12 pro kit i think lowering of 30\30 (not sure) and i wann buy ronal aero wheels..specs are 16 \ 7,5 wide and et 38.... my question is...can i run this setup with no fender rolling ...i dont want it to look like crap under the fender... can someone post pictures with these wheels or with similar setup...thanks and i hope i can get an answer ...:D
      sasha
        Suggestions on tire size please. 16x8, 16x9 et15 all around suspension will be megan coils, spun low. Will I have any rubbing issues with this offset?
        Thanks.
        (OO=[][]=OO)
          I'm looking at running BBS RS070 15x7 et16 all around.
          I'm on IE3s with Konis on a late model.
          Do I need spacers?
          Will I rub?
          Do I need to stretch or roll the fenders at all?
          I have new 205/55/15 tires.
          Thanks!
            After doing my research and learning, I think I have it figured out,
            Please comment
            All for 1991 Vert
            Putting 17x10, et 15, on the rear.....
            1. Using skinny tires, streched makes it easier.
            2. Using full size tires like 255 means major rolling, pulling, and streching the wheel well which usually means repaint and the stock look/lines are gone.
            3. Slammed/Lowered suspension makes it even harder.
            Is that about it?
            Thanks
            Originally posted by der affe
            What are you going to start a thread about next? "My woman's skinny jeans chaffe my special parts, f*ck skin irritation"
            Originally posted by navid41691
            And no, I use lotion so I don't have to worry about skin irritation.
            '...rolling balls, i'm elated, i'm going dumb now; drinking liquor i'm faded and having fun now; loaded gun and tripping with everyone around; keep me stuck in the sky, i never wanna come down...'...kabosh
              these
              I dunno, I'd take a whole lot of OEM low offset wheels over those. But I see where you're going with it at least. :p
                sasha
                15-20mm spacers all around to fit them.
                  Thanks.
                  195/45 205/45
                  195/45 215/40
                  205/45 205/45
                  Etc etc. 215/45, 225/40, 225/45 will all require suitable amounts of fender massaging to fit in the rear.
                    Do I need spacers?
                    Will I rub?
                    Thanks!
                    Should fit without rubbing.
                      Please comment
                      All for 1991 Vert
                      Is that about it?
                      Thanks
                      You have the gist of it. In general anyone looking to run 255s on an E30 rear should be looking at +25 to +30 offset.
                        195/45 205/45
                        195/45 215/40
                        205/45 205/45
                        So if I do 195/45f, 205/45r, I'll be able to get away with out rolling?
                        Would 205/40 not be enough sidewall? Would prefer to have a little bit of beef to the tires so the 45's sound good but also don't want rubbing. Thanks for the reply and help.
                        (OO=[][]=OO)
                          Is this with severe fender rolling? As I understand it, a positive offset=more back spacing. so if a person wanted say 275 in the rear getting closer to a 0et would push the wheel away from the shock for clearance.....correct?
                          Instagram @rebellionforge
                            Yes, I'd suggest the 195/45 205/45 combo if you want to avoid rolling. 205/40 is too short of a diameter for an E30.
                              Yes, about the largest you'll get to fit on an E30 with just a basic fender roll (and NOT rub) is a 245. You're right on the offset explanation.
                                I have dtm flares That I'll be using. No rolling involved because I'll cut them out!
