I've got a staggered set of 15x8,9 et-9 that I'd like to go on a 91 318is. Is is worth trying to get these to fit? If so what tires?
This is a sticky topic.
Originally posted by mclaaron View PostI've got a staggered set of 15x8,9 et-9 that I'd like to go on a 91 318is. Is is worth trying to get these to fit? If so what tires?
Edit and you'd have to roll the piss out of your fenders.-Christian
'37 Chevy pickup, the über projectOriginally posted by roguetoasterBe sure to remind them that the M42 is one of the best engines ever made, but be sure to not mention where it actually falls on that list.
What adapter would I need to run some 5x120 et 35, 17x8 wheels with a 72.6 CB. I already have 205 40 17 tires. I've seen some ppl with 20mm adapters, would that be ok? I'm rolled pretty well all around too.Last edited by blck325is; 11-19-2015, 04:23 PM.Originally posted by csermonet47Vlad, you are handling this quite unprofessionally.
Also, you are a cock with tacky taste.
That is all.
Originally posted by word is bond View Post16x8 et 20. Has anyone tried running 215/50r16?
I want to avoid stretched tires so trying to fit something wider than 205 under unrolled late model fenders with bilstein sports and h&r sports.
Maybe better to roll the fenders and go with 225/45?
Sent from my SM-G900V using Tapatalk1989 325i S50 swapped
2007 4Runner Sport V8
Originally posted by word is bond View PostCool. Thanks for the response! What suspension are you running? Rolled fenders?
89 325I, Bilstein Sports with H&R Sport Springs, 18mm 5X120 adapters, Looking a set of Style 68's from a E46, I think spec is 17x7.5 W/ET41, 17x8.5 W/ET50, Too much offset correct?sigpic
Steve Corbett
1983 528E Scrapped
1983 528E Sold
1984 745I
1984 325E - Sold
1989 325I Bronzit-Sold
1989 325I Zinno
1988 635CSI
Hello guys,
I have e38 style 5s that are currently being filled, drilled, and custom hub size. The bore size is being reduced to 57.1mm so I don't need to use hub rings.
My question is what is the widest tire I can fit on the front wheels?
I currently have basket weaves with 205s in the front and it is barely missing the front struts. Now to wear these wheels on my car, I would need 5mm spacers. And with an et23 I believe the biggest I can go up front is 215. Is this correct?
Also, what is the biggest I can go in the rear? 225? Car is pretty low, but not slammed.
E30 5 lug swap.
e36 m3 up front; on shortened struts and ground controls
318ti rear
Wondering what i would need to do (spacer size) to fit these tire sizes comfortably.
Front - 17x7.5 ET41 with 225/45
Rear - 17x8.5 ET41 with 245/40Originally posted by Lof84 doors allow you to transport more whores.
therefore, their value is much greater.
Hey guys I have been living in this forum, and google.
I'm interested to get the guru and the boards opinion for a good setup.
Car is an m50 swapped 88 vert. Suspension is H&R cab springs on yellow adjustable struts.
I want to run 16x8+15 & 16x9+15 what tire and spacers should I run?
Thanks,
