Main Bearings and measuring my crankshaft
  • Delahay
    • Feb 2022
    • 15
    I have a 87 325is Early production year. The motor is open and I will be replacing the bearings. How do I know if I need standard size or .25? The current ones do not have a stamp on them and I do not have a micrometer tool.
  • It's Soda Not Pop
    • Jan 2022
    • 877
    You could take it to a machine shop and have them measure it.
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • digger
      • Nov 2005
      • 6196
      Buy a cheap verniers they will get within 0.25mm for less than $20. Doubt it would be o/s
      • e30davie
        • Apr 2016
        • 1788
        I would just get a micrometer. Got to be cheaper than rebuilding the engine twice.
        • moatilliatta
          • 6152
          If you're that far along, you'll find another use for the micrometer. Maybe used re cert higher end set, ebay? Mcmaster if you're in a rush.
          Probably STD like stated above.
          Just note: Full groove main bearings need modified caps to fit if you go that route going back together.
          @Zakspeed_US
          • McGyver
            • 4636
            Buy 1 bearing and plasti-gauge. Measure all your caps with the known value and order the remaining bearings as needed. (or buy the correct tools)
            • TobyB
              • 5291
              Inexpensive mics are more than accurate enough-
              if you're this far, they're a small percentage of the project cost.
              t
              it's a slippery slope
              • digger
                • Nov 2005
                • 6196
                why do you need a mic for this job? a plastic vernier will tell you within 0.25mm and plasti gauge for the clearance. if you are doing it the professional way you need a mic but also some other bits that are pretty spendy
                • TobyB
                  • 5291
                  Ah- point taken. I went 2 steps farther and assumed OP would want to make
                  sure the crank was in spec.
                  The $10 HF digital caliper would be overkill, even.
                  t
                  measures twice and then forgets.
