3D Printed Parts Survey
  • sert57
    • May 2014
    • 170
    a tool kit for the trunk that you could customize for other tools would be neat.
    • e30davie
      • Apr 2016
      • 1788
      Ive got a 3d printer myself and i dabbled with making little widgets here and there. The issue i think is that 3d printed parts by nature dont have the best texture to them, they are made in layers so you'll always see the layers. Make the layers small enough and it can look ok, but it wont match the rest of the interior parts on the car.
      Best idea ive seen is to hit it with some spray bog, sand it back and then paint it with good paint. but its alot of effort when it might be easier to just track down a new/good condition OEM replacement piece. Or you hit it with an alcantara/swede/leather covering.
      Proptotyping and making moulds i think is where 3d printing is at the moment in the automotive industry, not necessarily producing finished pieces. Unless of course its where texture doesnt matter. The remote control plane/car/drone guys are having a ball with 3d printed parts. Though i have made a few brackets and bits and bobs for my car with the 3d printer but they cant be seen etc.
      • noid
        • 1537
        You can acetone vapor ABS to become smooth.
        Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
        Your resource to tools and tips: www.rtstools.com
        • e30davie
          • Apr 2016
          • 1788
          Interesting.
          I wonder if you can maintain tolerances using that method. Depends what you are making i suppose as to weather that is an issue or not.
          • vtechnik
            • Jan 2018
            • 379
            That's really cool. The one on the left almost looks like a piece of ceramic. I also like the tool box idea mentioned above.
            1988 ~ Lacey ~ 325iS
            • digger
              • Nov 2005
              • 6162
              most 3D printers people buy for home projects are toys and the quality is average with limited materials. a high end machine makes some good parts and some materials are quite impressive
              • varg
                Florida Turbo Man
                • May 2014
                • 3406
                Originally posted by Andre3127
                What kind of plastic did you use?
                I didn't print it, but if I had to guess based on appearance I'd say it's ABS.
                I only just ordered my first 3D printer, once I have it and start printing I'm sure I'll be able to identify materials a little better.
                IG @turbovarg
                '91 318is, M20 turbo
                • jgilber0
                  • Nov 2016
                  • 457
                  Convertible top strut sleeve. NLA and generally needed when replacing the struts. ABS would probably be a good choice.
                  P/N 54311943751
                  Description here: https://www.ecstuning.com/b-genuine-...e/54311943751/
                  Jon (OO=[][]=OO)
                  1992 325ic white, stock with a 5-speed swap
                  Palm Beach County
                  • ainadude
                    • Apr 2008
                    • 221
                    Since we're fantasizing ... dashboards (wouldn't that be nice?)
                    ainadude
                    Indian Wells, CA
                    1991 325i 2dr. 5sp, delphin, w/freshly re-skinned IS sport seats/15" Ronal cross-spokes
                    1976 Triumph Spitfire w/1.8-liter Miata engine/transmission, koa dash with TR6 oil/volt gauges, lowered suspension, 14" Minilite replicas and more
                    2004 Kawasaki ZZR600
                    • McGyver
                      • 4635
                      I've been meaning to make a replacement of the plastic section of the rear pop-out window latches. I've had a half broken latch on my desk for months, just haven't gotten around to modeling it yet.
                      But I do have a 3d printer in the cube next to me!
                      Item 4:
                      • me_john85
                        • Jun 2018
                        • 40
                        The left and right convertible flapper piece.
                        • LowR3V'in
                          • 4209
                          Tweeter pods like factory.
                          • Kershaw
                            • 11822
                            Like this?
                            https://squaredmotorwerks.com/products/m50-tps-adapter
                            I'm not sure how well this plastic would stand up to heat. I'd have to find dimensions and someone to test it for awhile through heat cycles.
                            Why bother with plastic at $27 when aluminum ones are $35?
                            If the plastic one was $15, I'd say there would be a reason to get plastic.
                            AWD > RWD
