e30mclow's e30 #14 - Now 1.5jz + 6 Speed
  • e30mclow
    • Jun 2010
    • 203
    #166
    Originally posted by formyhealth
    Too cool sir! Any HP figures?
    I should have it on a dyno very soon.
    Meanwhile, I finally put on the Alpina 162 valance
    • s14brent
      • Mar 2014
      • 574
      #167
      valance looks great man! on your gta wheels, did it cost you much to machine out the hub bore? I've been looking for some cheap 16x8+0's.
      89 325i 4dr s52
      02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
      21' Toyota Tacoma TRD OR 4x4 6 speed Manual
      • e30mclow
        • Jun 2010
        • 203
        #168
        My man, all I did was stick a 40 grit flap wheel on the end of a DeWalt drill and have at her.
        It self-centers as it rotates and you're only taking off less than a mm.
        No balancing issues.
        More Alpina stuff - may need sideskirts.
        Can't wait to put the GTAs back on this week.
        Also, some highly articulated suspension shots from Sunday (pre-Alpina)
        • varg
          Florida Turbo Man
          • May 2014
          • 3439
          #169
          Is there more room behind that valance than the stock 'is' one?
          IG @turbovarg
          '91 318is, M20 turbo
          • e30mclow
            • Jun 2010
            • 203
            #170
            I can fit the Alpina valance with the iS valance still attached behind it. This hangs about 2" lower.
            An unforgiving bastard to fit through, as there is zero flex to the Alpina items.
            • varg
              Florida Turbo Man
              • May 2014
              • 3439
              #171
              Good to know. At some point in the future I will be seeking more room behind the valance, since my massive intercooler makes it impossible to run a condenser fan with the stock, cut up, valance. I love the look of the Alpina valances and would not be opposed to trimming a reproduction and putting it on my car.
              IG @turbovarg
              • e30mclow
                • Jun 2010
                • 203
                #172
                Did a thing
                470HP & 354Tq
                VIDEO -
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3439
                  #173
                  Nice, that is a lot of power. Power to weight ratio has to be on par with a C6 Z06, assuming the car weighs close to 3,000lbs. How's the traction?
                  IG @turbovarg
                  • e30mclow
                    • Jun 2010
                    • 203
                    #174
                    Me + Full Tank + Full Interior =
                    Spins 4th no problem.
                    I'll be upgrading wheels this winter to try and fit 245s.
                    • tyeler18
                      • Jul 2019
                      • 141
                      #175
                      That's a great power to weight! I'm just a bolt on LS1 car but I've got 245 square A052's on my HPDE car and they hook up great for the track. I'm Probably 150hp and 50ftlbs less but you should still have reasonable traction on a 245
                      • e30mclow
                        • Jun 2010
                        • 203
                        #176
                        Can you post of photo of the 245 square setup? 16s or 17s?
                        My fronts are a challenge as my front track width is about 15mm wider per side.
                        • tyeler18
                          • Jul 2019
                          • 141
                          #177
                          16x8 +20 square here, 24.8" tall tire, so any 17 in a similar offset will work as well. This is completely stock suspension minus M3 offset FCAB's. Coilovers and camber plates would get a +25 or similar under the fenders better. I tracked it all night saturday night like this with minor rubbing, 99% of it due to the stock springs being so soft the tires were in the fender liners all night.
                          Untitled by Tyeler Andersen, on Flickr
                          • e30mclow
                            • Jun 2010
                            • 203
                            #178
                            Here is a photo dump of progress:
                            2.93 LSD Fitted
                            Burned off all available tires before the snow hit
                            Tucked it in beside the Pajero Evo for the winter
                            Finally found an immaculate carpet to replace the terrible one that's in it
                            Bought a terrible winter car while the Evo is being kept safe
                            Converted the front core support to a removable setup
                            Now the engine and trans can come out in about 40mins from start to finish
                            Replaced the decimated throw out bearing
                            Soundproofed/Heat shielded the tunnel and bay
                            Deleted any unnecessary wiring now that the ABS & Airbag are gone
                            Did the timing belt, water pump, tensioner and a few other things to the 1JZ
                            Chopped out any unnecessary bracketry in the bay
                            Started looking at clocking my BC top plates to gain more caster without changing the wheel position
                            I'm going to re-drill the stud locations to rotate the plate 30degrees, which will increase caster about 20mm and keep the strut towers untouched.
                            Made a rather large purchase - BBS RSs
                            16x8 et11 Front
                            16x8.5 et5 Rear
                            Perfect for my suspension setup!
                            • 2mAn
                              SeƱior Mod
                              • 21093
                              #179
                              A+ photo dump
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              Make R3V Great Again -2020
                              • e30mclow
                                • Jun 2010
                                • 203
                                #180
                                More photo dumpage
                                Launch control mawfakers....
                                Micro momentary switch
                                All wired up with a quick disconnect in case I need to pull the trans
                                I made a neoprene sleeve to keep the wiring semi-clean at least
                                I could have easily worked it off of the clutch switch, but this is just so much more of a cool gimmick.
                                My new carpet is in, which meant sacrilegiously cutting it up to fit the modified tunnel.
                                Redid all of the crusty in-bay loom
                                Sharpie'd by cluster and polished the screen to a near new finish
                                The interior is now ready for some serious ripping this summer
                                Fitted the ultra-rare SedanKing Heckblende
                                I'm finishing up a neat license plate holder, as this one was just for mockup.
                                Next up is a deep clean, then she's back on the road this weekend!
