The Super Nuova...
  • Reichart12
    • Aug 2012
    • 2168
    #226
    Originally posted by 2mAn
    Looks like some progress is coming along with this... As Im one to do, the search for a crankshaft let me down a path and it looks like Im going to be doing a little more work. Stay tuned
    This seems like it could be crafted into a family motto for you.
    Instagram: Reichart12
    • 2mAn
      Señior Mod
      • 21093
      #227
      So... I did a thing. I was looking for a 2L crank and got derailed in two totally different directions. The Twin Spark project is continuing but I’ll wait until something specific has happened before I share those details. The other thing that happened was I found a 2L crank, attached to a good, used 2L motor. Price was too good not to say so and the timing was just right for my brother to deliver the motor to me.
      So now I have a 2L motor that looks good to go, though I’ll look at adding some fresh gaskets and resetting my Weber 40s to work. Main thing I need to figure out if I want to buy a shiny header or not. I could also swap in my Euro Cams as I think they will be better than the Jetronic cams that (I believe) are currently in the motor.
      Pros, let me know if any of these numbers mean anything to you. Also taking suggestions on what gaskets I should change while I have it on the stand.
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • Chilezen
        I weld cats
        • Dec 2013
        • 1944
        #228
        So if I understand this correctly,
        You'll swap out the current motor for this "new" 2L motor, while fiddling with the twin spark motor in the background? Is the new motor a drop-in fit?
        Currently building a badass coffee table
        Random stuff on insta @kevanromero
        • 2mAn
          Señior Mod
          • 21093
          #229
          Thats the current idea... we'll see if I actually do it. I can swap over my Euro Cams, & Weber carbs (with some minor changes) and get a nice bump in power without doing any major changes... The Twin Spark build is getting a little more complicated so this buys me time and more power in the interim
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • MrBurgundy
            R3V Degenerate
            • Mar 2012
            • 5616
            #230
            Most def the oil pan, timing covers and rear main while it's on the stand.
            • 2mAn
              Señior Mod
              • 21093
              #231
              Definitely, I’m cleaning all the rtv off. I’m used to the red stuff, but the pan and timing cover has some blue stuff I’ve not seen before
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              • 2mAn
                Señior Mod
                • 21093
                #232
                Took the car out to the Cars and Coffee Los Angeles that happens at the end of each month and saw a few other Alfa’s out there. The Giulia got a lot of love and I had several people telling me they are looking for one. Parked it so the pics would be from the good side lol
                After delaying it, I finally got in the garage with determination to get (at least) the rear door off. Wasn’t too bad, I prepped myself for battle, but finding this cut down Allen that was from my Datsun Fairlady days it turned out to be exactly what the Dr ordered... for the rear door at least
                Once I broke them loose, I knew it was coming off. Today, it came off.
                The front door is going to be another battle. I pulled the smaller pin that restricts how far the door will open hoping to get more access, but that didn’t help as I hoped. Tried to knock the major door pins off and that also wasn’t successful.
                Content with today’s progress I called it a day. Posting here hoping for some ideas.
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • Chilezen
                  I weld cats
                  • Dec 2013
                  • 1944
                  #233
                  Find a concrete pole, park next to it. Open your door. Throw it in reverse.
                  Hehe.
                  Well I don't think this will get you much further, but pull off the inner door skin and peel back the plastic liner. See if there's anything inside the door there that will help you. The only other idea I have is welding other pieces of metal to the pins to increase your ability to pull/punch/whack them out. But I can't really say without staring right at it again.
                  • roguetoaster
                    Biggus Tippus
                    • 7830
                    #234
                    Is that green below the hinges an original color or a weird primer?
                    • 2mAn
                      Señior Mod
                      • 21093
                      #235
                      It has to be a primer of some sort as I've seen it in a few other places too... its definitely not the original color. This blue is 100% the original color, though not the original paint in most areas.
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      • 2mAn
                        Señior Mod
                        • 21093
                        #236
                        Lots of work done. Pictures alone wouldn’t do it justice, which sadly means you have to listen to me yap for a bakers dozen
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • hasa
                          • May 2013
                          • 307
                          #237
                          It is interesting to see this project and you working on that in a video. edit: it seems to be possible to embed the stuff with video-tag.
                          • 2mAn
                            Señior Mod
                            • 21093
                            #238
                            A quick summary of the last month... welding
                            Nearly done with all the welding!...
                            And finally starting to grind it all down to be smooth.
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            • Northern
                              I like cupcakes & sh!tboxes
                              • 5287
                              #239
                              what's the plan for the inside/backside of all of that? leave it bare or flood it with fluidfilm or what?
                              Not nearly as much of an issue for you, so not sure what is customary where rust isn't nearly as much of an issue.
                              Originally posted by priapism
                              Originally posted by shameson
                              • e30m3s54turbo
                                • Jun 2010
                                • 3295
                                #240
                                Looks good. I hated to see rust on my projects. I learned to get rid of myself to save money.
