Newman's E30/Skyline swap thread
  • newman
    • Mar 2007
    • 1159
    #361
    Originally posted by s_ribs
    Yep, looked through that soon as I saw the link. Good stuff - nice documentation. That's a lot of extra work to do while doing a project!
    True, but the documentation helps me gather my thoughts, make plans, and remember things I did. It's invaluable.
    1987 325is: 495whp/400ft-lb
    UPDATED 03/12/10!: RB26DETT Swapped E30
      • 34834
      #362
      Originally posted by newman
      I am PRETTY sure that is (or is very similar to) what I had on my 240sx (satin black). It got all rusty after about a month. I was pretty bummed out. (side note, check out that brake booster placement... that was an RHD CONVERSION, lol... I'm a ricer)
      Before:
      After (don't hate on my manifold too much, it was my first one ever...):
      hopefully it's not. I was going to do the satin aluminum color. I wonder if the polished has better corrosion resistance? also were those stainless manifold pieces?
      • newman
        • Mar 2007
        • 1159
        #363
        I hate getting gear oil in my hair...
        02/12/10 - Pre-startup details
        • newman
          • Mar 2007
          • 1159
          #364
          OK i'm really shooting for starting this this weekend...
          • psyber_0ptix
            • 904
            #365
            video please!
            Originally posted by FredK
            However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
            My year in Germany
            Feedback
            • newman
              • Mar 2007
              • 1159
              #366
              I promise there will be one. My AEM buddy is coming over tonight, so we're gonna try and start it. :)
              • evil_twin
                • Nov 2007
                • 2965
                #367
                get footage or it didn't happen.
                Paypal: vdang5@gmail.com
                Delta Auto Care
                2875-C Towerview Road
                Herndon, VA
                703.435.1375
                My Feedback Thread: Evil_Twin
                • newman
                  • Mar 2007
                  • 1159
                  #368
                  I'll see what I can do.
                  • Jesse30
                    • Jan 2007
                    • 3936
                    #369
                    looking forward to an update. i wanna see it running!
                    • newman
                      • Mar 2007
                      • 1159
                      #370
                      No dice on startup. Something is haywire with my EMS.
                      The way the ECU turns on things like the fuel pump is by grounding the negative side of a relay coil. Well, for some reason, the drivers are closed when off and open when on...
                      There is also a problem with the coils not firing, although the Cam Angle Sensor syncs perfectly.
                      I am probably going to have to send it back to AEM.
                      • evil_twin
                        • Nov 2007
                        • 2965
                        #371
                        sigh...
                        Delta Auto Care
                        Herndon, VA
                        703.435.1375
                        • Farbin Kaiber
                          Lil' Puppet
                          • 29502
                          #372
                          Maybe that what18yahoo or whatever his name is can come help you troubleshoot?
                          • newman
                            • Mar 2007
                            • 1159
                            #373
                            Lol. So many people keep telling me I wired the relays wrong. They need to STFU.
                            • SamE30e
                              • Sep 2007
                              • 4319
                              #374
                              Check, check, then double check. lol
                              1985 325e 2.8 Turbo VEMS
                              • Iain
                                • Oct 2005
                                • 2815
                                #375
                                It's painful, but we had an issue on a 'rod I helped build where the loom was pulled and stretched slightly getting it in the car and it had done 2 things - pulled a pin slightly out of a plug and also broken the wire inside the sheath (a prick to find), causing weird start/idle issues.
                                Can you get any diagnostics up on the ECU? See any weird signals?
                                Pork Hunt Motorsport
                                eBay is like the summit racing catalog for today's special Olympics crowd
