e30guydownunder: Project M42, probs definitely got more power than your S50
  • e30guydownunder
    • Jul 2008
    • 874
    #211
    Originally posted by e30guydownunder
    All thats left is to make some hub centre extendo's for the fronts (like the Turner Motorsport items). And one more rear brake rotor spacer. Then I just need to order the new front hubs and rear wheel bearings. My press in studs are here ready to go.
    Originally posted by DTM190
    Good work slutbags, hope you made 2 of everything ;)
    I know your only Teasing but Im fucking tired! Went to work at 5 before I came home and played silly buggers in the shed all day!
    More importantly I made sure I handed the caliper adapters correctly ;)
    - Chris
    Project M42 - 255 @ 19 psi
    • SA E30
      • 1248
      #212
      It's coming along nicely! Can't wait to see the turbo motor in the full chassis and out the quarter ;)
      • e30guydownunder
        • Jul 2008
        • 874
        #213
        It's out of the quarter.
        Unfortunately I pulled it down today ready to send off for machining and looks like the crank has been overheated to buggery. Has the blue temp marks you get on exhausts!
        Going to strip down the other spare tomorrow and hopefully that crank and block is good to be sent off for machining.
        - Chris
        • SA E30
          • 1248
          #214
          Ohhh! Me likey!
          Sucks about the crank tho!
          One more question, which I missed what master cylinder brand are you using for your master cylinders? They look just about what I want to use on my retro fitting of the stock hand brake handle to hydro conversion... I want the ratchet and stock brake as it's going into my street car.
          • e30guydownunder
            • Jul 2008
            • 874
            #215
            They are PBR Mastercylinders. I can't remember the exact model numbers, but I just went to the local brake shop and picked them out of the catalogue. Old Toyota Celica Clutch Master cylinders are very similar (from memory) and this is what people used to used for a hydraulic handbrake.
            - Chris
            • F34R
              sLaughter
              • 12376
              #216
              I did not read much of it, just the parts you bought and saw the pictures. Over all nice build! FYI the Groton control arms are shit. I ruined a set in a season of tracking. Meyle all the way =)
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • e30guydownunder
                • Jul 2008
                • 874
                #217
                My Groton arms are still going strong, this is the third season and I don't go easy ;)
                - Chris
                • e30polak
                  • 6136
                  #218
                  Wow, I can't believe I never read your build thread. Very impressive work, can't wait to see it all buttoned up! :bow:
                  INSTAGRAM: @UNDR8D_EMPIRE
                  • e30guydownunder
                    • Jul 2008
                    • 874
                    #219
                    Cheers Polak, I dont seem to be getting much interest from most of the major players on the forums, but I'm cool with that. Doing for me more than anything :)
                    Yes that time again. Update time :)
                    I have been busy.
                    I stripped down the rear end, pulled off all the old brakes to discover the rear wheel bearings were absolutely stuffed. Just as well I ordered new ones for when I pull the rear hubs!
                    Hubs were removed, holes thru drilled and studs fitted! These babys are only $3.50ea compared to Vorshlags $6.60ea....AND they will never be at risk of backing out, galling or just plain falling out! Obvious complication is you have to remove the hubs.
                    Anyway the progress!
                    New hubs fitted in the arms with new bearings and new studs.
                    Slip on the rotor spacer
                    Slip on the rotor, locating bolt thru it and the spacer. Slide on the caliper and caliper bracket
                    Bam Rear Brakes done. Yes I checked and no the standard handbrake does not work. But I already have a locking hydraulic one on the way :) This will be plumbed inline, not the most ideal (for the hardcore drifter) but will do for me. Will be used to park, and screw around at skidpan days :) maybe the occassional drift practice if I get bored.
                    Here is a front hub with the studs installed:
                    Boy they look long? Well not really once I have all the brake hardware on there and my 12mm spacers :D
                    And a picture of the front setup, your average guy will be none the wiser :D Hopefully they will be up to the task!
                    Note Front hubs not installed as I am negotiating some new coilovers currently and will wait to install the new hubs on the new struts!
                    - Chris
                    • KamakaziX
                      • 2041
                      #220
                      Epic build thread is epic.
                      Originally posted by lambo
                      Fuck studying. Party hard.
                      • Dj Buttchug
                        • Jun 2010
                        • 7688
                        #221
                        this.
                        also lemme get those brakes plz. looking good :up:
                        Turbo M42 Build Thread :Here
                        Ig:ryno_pzk
                        I like the tuna here.
                        • e30guydownunder
                          • Jul 2008
                          • 874
                          #222
                          nah man they mine :D thanks for the support guys Im working on getting there!
                          Aiming for new coilovers, brakes, engine moved back and rebuilt with the cams but no turbo just yet, not gonna have time to reqire the whole fusebox before 29th July!
                          After that come home rip the electrics apart and fit the turbo / ecu
                          - Chris
                          • 89is
                            • Dec 2010
                            • 224
                            #223
                            love this thread, subscribed.
                            Originally posted by Wh33lhop
                            If you actually stay within your budget, you are not a true car enthusiast. True story.
                            • e30guydownunder
                              • Jul 2008
                              • 874
                              #224
                              Originally posted by Iain
                              $7k could get you some pretty decent turbo Subarus. Gen1 RS Lib wagon or early (94-96) WRX wagon is in your price range.
                              $7k turbo GX/WRX conversion would be stretching it. $10k is more like it.
                              A mate's Gen2 sedan. He'd take $7500 i reckon
                              http://www.rslibertyclub.org/forums/...ad.php?t=88070
                              Gen1 Legacy wags in Melb
                              http://www.rslibertyclub.org/forums/...ad.php?t=89667
                              Gen1 GX-WRX conversion near you
                              http://www.rslibertyclub.org/forums/...splay.php?f=87
                              Iain is a waffleswaffleswaffleswaffles
                              nice distraction this lot was
                              - Chris
                              • e30guydownunder
                                • Jul 2008
                                • 874
                                #225
                                Aight Time for me to come clean. Forgive me poor souls, for I have sinned
                                - Chris
