e30guydownunder: Project M42, probs definitely got more power than your S50
  • e30guydownunder
    • Jul 2008
    • 874
    #376
    Cheers guys, I'm super stoked
    - Chris
    Project M42 - 255 @ 19 psi
    • wazzu70
      • Jan 2005
      • 1143
      #377
      Whats your compression ratio?
      Also, can you share a screenshot of your ignition map? Understandable if you don't as you paid for it!
      -Nick
      M42 on VEMS
      • e30guydownunder
        • Jul 2008
        • 874
        #378
        I am running CP 8.5:1 pistons and the copper head gasket is a little thick probably 2mm but I never measured the actual compression numbers.
        - Chris
        • Massimo
          • Jan 2008
          • 3207
          #379
          You are running stock rods and crank? Congrates as well. Makes me want to go turbo and not N/A specially if I can pull 220+kw with stock rods and crank.
          • wazzu70
            • Jan 2005
            • 1143
            #380
            The stock crank is plenty strong. The stock rods are decently strong as well, but it is an area I would consider upgrading if you had the money.
            In the bottom end, the factory pistons are the weak link.
            -Nick
            M42 on VEMS
            • e30guydownunder
              • Jul 2008
              • 874
              #381
              The stock M42 (not M44) crank and rods are forged. I am quite confident this setup will go close to 300kw once I wind the boost up more. I kind of wish I put rods in it, because my tuner was being a girl about revving it any harder :P
              - Chris
              • e30guydownunder
                • Jul 2008
                • 874
                #382
                Made it through the first event not without drama but I made it!
                -coming home from scrut Thursday night got a flat tyre on the trailer (not so fun)
                - Friday morning same wheel feel off trailer, broken stub axle!
                - Monday morning rip exhaust off car trying to get off borrowed trailer. Got it patched up just in time for first run.
                - Second run intercooler pipe comes off, hmmm did that on dyno, reassemble should be sweet.
                - Third run, nope off it goes again.
                - Fourth run all apples, rigged up some dodgy tie straps to the inlet.
                Obviously this turbo setup was never going to be super awesome for a Hillclimb, add in that I had installed a 3.46 diff to suit Wakefield and Eastern Creek and it wasn't super pleasant. But I am pleased to have had a day out, simple easy to fix dramas and it came home straight and ready to go again, more than can be said for a number of cars that were competing also.
                Got some sweet pics too :)
                - Chris
                • S13_E30
                  • 309
                  #383
                  Awesome pics!
                  • eduTechnic
                    • Dec 2012
                    • 400
                    #384
                    That's intense! Keep sharing. Sharing is caring.
                    Turbo M50 4 Door Build thread here 4 Sale thread
                    • e30guydownunder
                      • Jul 2008
                      • 874
                      #385
                      Intense? Nah thats just me driving, was pretty average too! Amazing how much confidence you loose after a year out of the seat!
                      I booked some time off work so now I gotta get it prepped for Eastern Creek (same track as WTAC) on 25th of October.
                      - Chris
                      • MF DOOM
                        • Apr 2012
                        • 944
                        #386
                        Car looks great!
                        • wazzu70
                          • Jan 2005
                          • 1143
                          #387
                          You have a ZF trans I assume?
                          Would you want more gear or less?
                          I have 3.73 in my car with a ZF, but havent been able to drive it much to see if its too much gear.
                          -Nick
                          M42 on VEMS
                          • e30guydownunder
                            • Jul 2008
                            • 874
                            #388
                            Nick,
                            It's a Getrag G260 and 3.46 rear. The car will do 160kph in 3rd gear. So yet it was a bit too tall for the smal tight Hillclimb. Bit should be perfect for holdi 4th gear at Wakefield and winding it out down the straight at Eastern Creek
                            - Chris
                            • wazzu70
                              • Jan 2005
                              • 1143
                              #389
                              Gotcha, I didn't think about the 260. Yea that wouldnt be the best gearing for a hillclimb!
                              Unfortunately we dont really have much for hillclimbs here. I am jealous you have the opportunity to compete in one!
                              What class do you compete in? Is it based off engine displacement (plus multiplier for FI?)
                              -Nick
                              M42 on VEMS
                              • Dj Buttchug
                                • Jun 2010
                                • 7683
                                #390
                                this build wins all m42 boost builds, including mine. props
                                Turbo M42 Build Thread :Here
                                Ig:ryno_pzk
                                I like the tuna here.
                                Originally posted by lambo
