ttrousdell's Project Thread (E30 M3 & S38 swap content)
  • F34R
    sLaughter
    • 12376
    #346
    Originally posted by ttrousdell
    Glad I got to make the trip up. Ill be back again with the e30 and more ammo. Ive considered that idea.
    I'm glad you made it up too! was awesome having you and the GF here for the little bit you got to stay. You better bring the e30! I'll show you all our amazing country roads here.
    Loved all the shots and work! you did the s14 right by cleaning and refreshing for seals/gaskets.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • DER E30
      • Sep 2013
      • 2349
      #347
      Love all the M power in this thread!
      -Christian
      • 2mAn
        Señior Mod
        • 21015
        #348
        What are your thoughts on the tires? I need to get a new setup soon and I was planning on getting the 225/45s all the way around but I like the thought of 245s in the back
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • ttrousdell
          • Nov 2009
          • 1770
          #349
          The car hugs the road very well. I really like this setup. You can fit the 245s on the M3 so why not.
          The 325is went through a lot of changes in the last few weeks. Mainly the swapping out of the S38. Ive grown really fond of my M3 with the S14. Going to try and make the car into a light good handling autox car for this coming season. I picked up this spare S14 so I decided to throw it in and see how I like it.
          Some last photos and video before the swap...
          Tore into it
          Worked into the night to get the s14 in
          Welding my rad support
          Made brackets to hold the radiator in its final position. Oil cooler in position too. went with Mishimoto for both radiator and oil cooler.
          For now ill be running mechanical fan with the shroud but will switch to an electric puller in time. Cutting the lines for the oil cooler to size. I just used a hacksaw to cut them. wrapped where I cut with duct tape to keep the fraying down. M18x1.5 to AN10 adapters needs on oil filter housing.
          Oil Lines in place
          Now the huge plenum from the s38 isnt in the way I can go back to assisted braking. Cutting the lines and flaring them to fit again.
          Much better fit then the s38.
          So I got the engine to start today so ill share the electrical side of things. To start this is a 89' 325is so again here is the body side of the C101 for that car.
          89' M20B25 C101
          1. Alternator Charge - BU
          2. Oil Level Static- GN/YL, BU/BK
          3. Not Used
          4. Cool. Temp - BR/VI
          5. Oil Press - BR/GR, BK/BR
          6. O2 Heater - GN/WT, GN/YL -12V
          7. Ignition Coil - GN - 12V
          8. Fuel Rate(econo) - WT/BK,YL/WT
          9. Tach Signal - BK
          10. Oil Level Dynamic - BU, VI/GN
          11. Inspection reset - WT/GN, WT/BU
          12. Check Engine - GY,BR/BK
          13. Fuel Relay - GN/VI,VI/RD 12V
          14. Speedo- BK/WT,BU/YL
          15. Unloader- BK/GN
          16. SRS/Not used
          17. ABS
          18. Starter - BK/YL 12V
          19. Not Used
          20. Not Used
          Now the 1989 M3 harness engine side C101. Which shares many similarities.
          2. Oil Level Ground - BR/OR
          3. Not Used
          4. Cool. Temp Gauge on Cluster - BR/WT
          5. Oil Press light cluster - BR/GR
          6. Diagnostic Port - GN/YL -12V & Evap Purge Relay BU/YL
          7. Ignition Coil Primary - GN - 12V Power Main Relay-GN
          9. Tach Signal - BK
          10. Oil Level to ground through resistor to pin#2- BR/OR
          11. Inspection reset - WT/BU
          12. Not Used
          13. Fuel Relay - GN/VI 12V
          14. Not Used
          15. Starter Unloader- BK/GN
          16. To Diagnostic Port- WT/BK
          17. Not Used
          19. Oil Temp(M3)-BR/VI
          20. Not Used
          To get this to work I simply depinned #2 and #10 since they go to ground on the M3 and not on the 325 and plugged them together. #6 is different but they both are supplied by a wire of the same size with a 15A fuse.
          Used the diagrams. Look up your car and look for C101 and next to it the pin #. Fairly simple.
          Few more things to note when swapping the S14 to 325
          • Throttle cable for s14 is longer M20 cable cant be used
          • Tranny mounts and brackets are different.
          • Motor mounts for S14 are taller.
          • G265 Shifter parts are different than G260,G260/6, and G280.
          Info on S14 bell housing sensors that i don't feel like re-typing
          More to come now that the engine is running.
          The Build:
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            #350
            Haha s38 to s14 swap in a weekend epic haha
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • QuiqueUy
              • Jul 2014
              • 127
              #351
              This is amazing , i have just finished reading all your thread and its amazing.
              Loved all the M power on this thread haha , keep up the good work !
              Can't wait to see some videos with the s14 :p
              • litu
                • 848
                #352
                Cool
                https://www.facebook.com/Cry_77_IX-110483784967661
                https://www.instagram.com/cry_77_ix/
                • jhaurimn
                  • Nov 2012
                  • 2224
                  #353
                  Curious to hear how the s14 compares in the 325 compared to the m3.
                  Current:
                  1989 325i
                  1988 M3
                  1987 325ic
                  Past:
                  2001 330ci
                  2001 M3
                  • CorvallisBMW
                    Long Schlong Longhammer
                    • 13039
                    #354
                    So what are the plans for the S38?
                    • rzerob
                      • Jun 2013
                      • 2315
                      #355
                      He has it for sale.
                      This is one of my favorite threads. I don't know if I would have done S38 to S14 but when I read you got a S14 I assumed it was going in this car. It will definitely be more nimble on the track than with the S38. I am looking forward to video. Keep up the good job.
                      • elmandatario
                        • Mar 2012
                        • 85
                        #356
                        Nice I was wondering what swap you was gonna do. I like how you always refresh the engine before the swap nice work. Definetley gotta see it in person during the warmer months
                        Ig: el_mandatarioe30
                        • The Dark Side of Will
                          • Jun 2010
                          • 2796
                          #357
                          Yeah, how much are the wider tires worth?
                          Going to run both at the same AutoX before you rip much out of the 325?
                          It's a 323 now, isn't it?
                          • F34R
                            sLaughter
                            • 12376
                            #358
                            Seeing as you plan on SCCA I think the S14 was a bad pick since it is all top end and SCCA is low end power for slow and fast in first-3rd.
                            As always, love seeing you do what you do! Stoked to do some driving this summer :D
                            Current cars:
                            ~ '87 535
                            ~ '06 X5 4.8is
                            • GDA
                              • 446
                              #359
                              Man this thread is so full of cool.
                              Numerous S engines and pics to show they are well cared for and used.
                              Very cool
                              • goarmy
                                • Nov 2011
                                • 622
                                #360
                                E30 has to be soo much happier now without the boat anchor
