Kamotors E30-Turbo to ITB M20
  • ForcedFirebird
    • Feb 2007
    • 8300
    #1786
    Originally posted by Good & Tight
    Revshifts guibo is a strong piece, no doubt. Survived countless launches with over 600ftlbs to the wheels. With an after market driveshaft it would make sense, but with a stock DS and the torque a turbo M30 makes the DS will fail.
    You gave me that, and it's really not really healthy anymore...
    john@m20guru.com
    Links:
    • kamotors
      • Nov 2007
      • 7102
      #1787
      7speedshop.com
      • ck_taft325is
        • Sep 2007
        • 6880
        #1788
        Hnng.
        Need a part? PM me.
        • delamaize
          • Nov 2013
          • 1430
          #1789
          hawtness.
          Dumpster Fire Pilot
          • kamotors
            • Nov 2007
            • 7102
            #1790
            stage 5 clutch. rated at 634ft lbs
            intake manifold mounted and 80lb injectors.
            7speedshop.com
            • AwakenNoMore
              • Dec 2010
              • 1291
              #1791
              What is your plan for the intake of this car? I've seen quite a few people block off the throttle body and cut a new opening on the opposite side to eliminate the need for lengthy and weird intercooler piping.
              1991 325i - "Scambles" The Daily Driven lightly modded.
              1988 Mazda RX-7 TII "Mako" The Free Dorito
              bacon by Jared Laabs, on Flickr
              • kamotors
                • Nov 2007
                • 7102
                #1792
                Not doing the reverse throttle for a while , didnt see it as needed.
                7speedshop.com
                • delamaize
                  • Nov 2013
                  • 1430
                  #1793
                  ITB FTW....
                  Just sayin'......
                  Dumpster Fire Pilot
                  • Wanganstyle
                    • 2828
                    #1794
                    Originally posted by delamaize
                    ITB FTW....
                    Just sayin'......
                    Not for turbo.
                    Single throttle is best for turbo; I'm sure he will eventually want to change to a biggie size one
                    • AWDBOB
                      • Aug 2013
                      • 4389
                      #1795
                      Dude, that 1.15 housing and big turbine wheel are going to make your car lazy as hell on an open scroll manifold.
                      You're not shooting for 800whp, why not run a 5858 or 6262? Similar peak power (6262 can make 700 with ease) with way more juice under the curve.
                      Just a thought, otherwise you might blow the welds on your intake manifold.
                      Also, you still planning on running pump?
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        #1796
                        Originally posted by Wanganstyle
                        Not for turbo.
                        Yes and no. Having a plenum full of charged air and ITB's, the throttle response would be slightly better, but not worth the extra expense/complication for no peak gains. Short runners and Large TB is more than adequate.
                        john@m20guru.com
                        Links:
                        • kamotors
                          • Nov 2007
                          • 7102
                          #1797
                          still going to run pump and methanol. If i dont like the turbo I'll simply sell, the 3.5L is strong outside of boost so I should be just fine.
                          7speedshop.com
                          • kamotors
                            • Nov 2007
                            • 7102
                            #1798
                            is it possible to run the turbo oil feed from the filter housings lid? just tap or weld a bung to the lid. I saw this and it got me thinking, if not I'll just run off the oil pressure switch.
                            7speedshop.com
                            • Bullet Ride
                              • Dec 2010
                              • 598
                              #1799
                              Yes. You can even see in the picture you posted that there's a pipe plug in the side of that lid... probably meant for adding a pressure sender.
                              • Alpina
                                • Oct 2004
                                • 838
                                #1800
                                That exhaust manifold looks fantastic
                                Sveinbjörn Hrafnsson
                                E30 CABRIO V12 M70B50 ///
                                ALPINA B10 BITURBO 346 @ 507
                                E34 550 V12 JML
                                Finnish wisdom : If you want to Win,, hire a Finn
                                http://alpina.123.is/pictures/
