Kamotors E30-Turbo to ITB M20
  • ak-
    • 12422
    #181
    Originally posted by kamotors
    also something is off with the AFR guage,when I let off the throttle it pegs at 22.4 but when driving around it fluctuates from 13-15after also occasionally it just reads HTR when stopped I'll go over the wiring tomorrow.
    That's normal. 22 off the gas while in gear.
    1991 325iS turbo
    • e46s54dr
      • May 2008
      • 1059
      #182
      Originally posted by Hey_You
      Anti-lag....or keeping your foot buried in the go pedal? Very clean engine bay I must say. I like it
      Its automatic. Butterfly is open thru shifts so constant boost.
      Awesome engine bay btw.
      • kamotors
        • Nov 2007
        • 7102
        #183
        auto transmission lol, although it sounds like anti lag when I let off after a pull.
        7speedshop.com
        • HR2L
          • 724
          #184
          HOLY BUTT NUGGETS! I just drove my turbo E30 and it is WAAAAAY faster than I thought, it kills my subaru in 0-60. its hitting 6psi in first by 4k and it smokes the tires into second, I only made it 4 miles before my intercooler pipe blew off and I had to drive home N/A:(
          Its normal for it to peg itself to a lean (or leanest) condition as you tip out by lifting off the gas pedal (I remember I had to get use to it with my LC-1 as well as when I had an AEM UEGO in my STI). Sounds like the gauge is working ok, you should be bouncing between 13-15 afr @ cruise (closest to stoich/lambda). Does the gauge go from HTR to CAL then your AFR readings comeback? This is an Innovate Motorsports AFR gauge correct? What are your WOT AFR's? The car sounds awesome, if I rolled on you I would swear you had a V8 under the hood the way your car is grumbling and loping! This really makes me want to build/turbo my m20 and not do an s5x swap, just to keep it OG under the hood. Also like the color options you went with under the hood for the valve cover and compressor housing, great touch! :)
          • kamotors
            • Nov 2007
            • 7102
            #185
            it just goes from htr back to a reading. I couldnt see my AFR guage when I hit full boost, I was too scared and looking at the road lol and I'm legally blind in my right eye where the gauge is mounted so I should probably move it..
            7speedshop.com
            • Hey_You
              • Nov 2009
              • 963
              #186
              AHHHH!!!! Now I understand the madness. Sorry, I like your car that much less now after finding out it's an auto, haha
              85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
              • pharow
                • Jul 2010
                • 1021
                #187
                We need a video of you driving it. Glad You got it running. Turbos and autos. You make me want to piece together a set-up for my car.
                '02 Outback wagon
                '87 325is 5sp
                '93 Kawasaki ZR1100
                • e46s54dr
                  • May 2008
                  • 1059
                  #188
                  Are you sure its smoke from the tires and not the torque converter? LOL. Jk. Cant wait to see the vids.
                  • kamotors
                    • Nov 2007
                    • 7102
                    #189
                    haha, the trannys not that weak
                    7speedshop.com
                    • e46s54dr
                      • May 2008
                      • 1059
                      #190
                      Im just messin with ya. Also, is that an accusump setup towards the firewall?
                      • TheTacoMan
                        • Nov 2011
                        • 2308
                        #191
                        Auto FTW
                        • brokenbimmer533
                          • 317
                          #192
                          Wide band sounds normal. Mine jumps around a bit while cruising but still stays in the general vicinity and goes lean when I let off the throttle.
                          • kamotors
                            • Nov 2007
                            • 7102
                            #193
                            yeah its a turbowerx system
                            7speedshop.com
                            • e46s54dr
                              • May 2008
                              • 1059
                              #194
                              Damn, I thought this was originally a budget build? I need to step my game up!:bow:
                              • kamotors
                                • Nov 2007
                                • 7102
                                #195
                                the total was under $1800 so its not bad
                                7speedshop.com
