yup, took away another 5 degrees of timing near peak torque.
Kamotors E30-Turbo to ITB M20
Originally posted by kamotors View Postall better:)
what does your timing map look like now?
Also I'm thinking of adding this valve for extra security and to really limit boost: http://www.928motorsports.com/parts/boostlimitervalve.php
I read in a few forum it Looks like its very popular..
Denny
___________
1990 BMW red 325IC M30B35 all stock Girlfriends ride
1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
Blogs:
http://bmw325e30.blogspot.com/ (restoration)
http://bmw325e30turbo.blogspot.com (Twincharge M20)
http://bmw325e30m62b44.blogspot.ca/
Originally posted by kamotors View Postseems like a controlled boost leak.
also MS can do overboost protection mine just happens to be set at 25psi
The BLV will limit the boost at what you set and wont move and keep the air circulating like you said a controlled boost leak.
I like the idea since it provides assurance especially with a turbo that can spike. If these could be made cheaper "hint hint" it would sell like crazy lol..Denny
___________
Blogs:
Originally posted by kamotors View Postits all a matter of opinion, some prefer clutch, I prefer torsen. Basically you can kick the clutch while going straight and you'll spin tires but you wont go sideways, on a clutch type the rear end is basically always going to kick out in some random direction.
Sent from my Galaxy Nexus using Tapatalk 2
Originally posted by kamotors View Posttook away some more timing near peak torque.
Here is my M30 timing map, I run E85 though.
Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
Originally posted by FLG View PostImo clutch diff's are much more predictable then torsen. Yes it might be better then a worn out stock unit, but comparatively a well built/not worn clutch unit will out perform a torsen, not to mention if you lift one wheel that torsen is now an open diff.
Its not an issue like i was on a worn diff since I've had 5 different diffs since I've owned the car, a torsen diff really doesn't fish tail under hard accell. I'm willing to bet drifters probably hate torsens for that fact.
also since I've done at least 2 snow season on each type of diff I can say a torsen is also MUCH more controlled for snow driving in about 1"-2" of snow, anything more and I just drove a different car.
7speedshop.com
