Kamotors E30-Turbo to ITB M20
I have the boost guage setup the same as my subaru and the wideband I havent decided on. I have a pretty neat VDO guage from the 80's that I got NIB. box was super yellowed and retro but the guage looks great. I dont have any pics but heres a pic to give an idea.It will make it easy so when I switch cars I dont look all over the place for gauges.
7speedshop.comComment
I need a little help wiring in my wide band I will be using it to simulate a narrow band signal.
My stock 02 pigtailasdasdasdasasd The innovate MTX-L
whiteasdasdasdasdasghghjghjdasdasdRed(switched 12v)
whiteasdasdasdasdasdasdaghghsdaisdBlack(ground)
blackasdasdasdasdasdasdasdghjjaisdWhite(headlight power)
greyasdasdasdasdasdasdhjkhasdasdYellow(analog 1 out 0v=7.35AFR)
asdasdasdasdashjkhjkhjkdasdasdasd Brown(analog 2 out 1.1v=14 AFR)
I'm confused... I've found write ups but non seem to have the same color wiring as me...Last edited by kamotors; 12-13-2011, 03:36 PM.
When I wired my m50 harness to my LC1 the colors were off as well. I used the pin numbers instead. Verifying the +12v and +signal with a multimeter so I didn't wire 12v to ground and melt shit.
Stock e30 o2
pin1 signal gnd
pin2 signal +
pin3 gnd
pin4 +12vComment
I hear ya, I struggled with electrical work until I had a lot of practice with megasquirt on my build lol.
Not familiar with the MTX-L but the manual that comes with it says white wire need to be wired to headlight power? Seems odd.
The white wire on my LC1 is GND.
Other than that looks good.
I had analog 1 (yellow) go to the ecu (megasquirt in my case) and analog 2 (brown) go to my AFR gauge. Programming the outputs accordingly.Last edited by brokenbimmer533; 12-13-2011, 07:03 PM.Comment
Not sure what the difference is between your wideband and mine (lc-1) but this is what I had.....
Analog 1 (yellow wire) as the narrowband. I have that hooked in to the stock o2 harness. That's the only thing I have in the harness. At first I used the 12v/ground/ground wires coming from the stock o2 harness but that didn't work. Readings were all messed up. So I used a switched 12v near the fuse box and grounded both wires to a bolt in the engine bay.
Make sure you have a good ground and a switched +12v, not a constant.Comment
the wideband works and E30 runs:) haven't driven it but I still need to clean it up a bit. I'm happy:) turbo area is smoking a bit? guessing its just burning off any spilled oil and what not.
HOLY BUTT NUGGETS! I just drove my turbo E30 and it is WAAAAAY faster than I thought, it kills my subaru in 0-60. its hitting 6psi in first by 4k and it smokes the tires into second, I only made it 4 miles before my intercooler pipe blew off and I had to drive home N/A:(
also something is off with the AFR guage,when I let off the throttle it pegs at 22.4 but when driving around it fluctuates from 13-15after also occasionally it just reads HTR when stopped I'll go over the wiring tomorrow.
