Kamotors E30-Turbo to ITB M20
  • Luis325
    • 3847
    #2761
    where are the vids KA????
    1986 "C2 2.7 Alpina" Sedan
    1987 325ic Black Vert
    • Wschnitz
      • 8089
      #2762
      The Videoooooooooo!
      willschnitz
      • kamotors
        • Nov 2007
        • 7102
        #2763
        well, ECU fried itself loading a tune today, fuel pump and tachometer freaked out. Now ECU wont connect.. car wont start....so yeah....
        here it was untuned on speed density
        7speedshop.com
        • Wschnitz
          • 8089
          #2764
          That exhaust popping though.
          willschnitz
          • kamotors
            • Nov 2007
            • 7102
            #2765
            needs some tuning lol
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              #2766
              BTW its so loud I had to put the external mic in the car lol
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                #2767
                here is how throttle calibrated during its death.
                :( satans chariot
                7speedshop.com
                • Kevinl
                  • Oct 2012
                  • 897
                  #2768
                  looks fairly quick it must run pig rich should be a beast once it gets tuned
                  1989 BMW 325is Lachsilber metallic 5 speed
                  2007 BMW 335i KARMESINROT 6 Speed manual
                  2011 BMW X5 35I
                  • iXguido
                    • Nov 2009
                    • 729
                    #2769
                    that oversteer though :D that sounds so amazing, driving impressions?
                    • kamotors
                      • Nov 2007
                      • 7102
                      #2770
                      perfect balance, I love it, just need ECU fixed now and then I can drive it everywhere.
                      anyone have alpha N tuning tips?
                      car wouldnt drive on ITB mode was just stuttering
                      7speedshop.com
                      • Wh33lhop
                        • 11705
                        #2771
                        dear lord, that sound.
                        paint sucks
                        • delamaize
                          • Nov 2013
                          • 1458
                          #2772
                          Boo for fried ECU.....
                          Dat sound tho.......
                          Dumpster Fire Pilot
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #2773
                            Fix your TPS signal for one. The closed throttle count should be less than the full throttle. You are relying on that TPS signal in your maps, I have found the signals are very unstable when you have the count reversed.
                            john@m20guru.com
                            Links:
                            • Bullet Ride
                              • Dec 2010
                              • 598
                              #2774
                              To further this I believe he's pointing to the fact that you may have a pair of wires swapped on your TPS wiring.
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                #2775
                                Correct. And while people keep telling me "it works that way" it's still not correct, and it gave us problems on the ITB builds we have done. Also, the more sweep you have, the better.
                                To add, on the street cars we had to increase the resolution at low TPS settings. Really thinking about doing dual maps in the future. Something like map1 0-10% throttle, map 2 10-100%. Local kid came by the other day with his m42 turbo. I was impressed with how smooth the car was having dual maps for increased resolution. He has 0-100kpa in map 1, 100-200kpa in another. Wasn't until I was adjusting some drive-ability issues on the Extrudabody car that I realized how nice the dual maps would be for ITB's in a DD.
                                john@m20guru.com
                                Links:
