Kamotors E30-Turbo to ITB M20
  • MPLFoster
    • May 2013
    • 1490
    #2821
    Originally posted by Jb325is
    Is your wideband AEM or Innovate?
    Are there any major differences between the two?
    form.follows.function IG @mplfoster
    • kamotors
      • Nov 2007
      • 7102
      #2822
      Originally posted by AWDBOB
      Snag a new wideband sensor. I would kill em more or less once every year in the Evo, that was an AEM unit, though.
      yeah, it just stinks because i did over 17 revisions yesterday because of the wideband saying it was pig rich! borrowing a friends sensor and tuning again today
      7speedshop.com
      • kamotors
        • Nov 2007
        • 7102
        #2823
        aem does not have as wide a range, not a fan here.
        7speedshop.com
        • MPLFoster
          • May 2013
          • 1490
          #2824
          I saw that when comparing the two. AEM's range is 10-20 and inovate uses 7-22. Besides that they have similar functionality? i guess what i'm asking is if one reads better than the other.
          • tinkerputzer
            • Jun 2008
            • 508
            #2825
            Have you tried resetting and recalibrating the wb?
            • 318aye
              • Jun 2010
              • 895
              #2826
              so from what I've learned, speed density worked fine floored and thats it. Alpha N or ITB mode is needed.
              I even have the vac. block and the signal is still too weak. Using the RHD tps and 318ti throttle cable.Ordered at the beginning of this M20 build so like 2 months?
              Ok. We most likely got the same TPS then. Keith sent me an alpha n map, is that what you started with?
              • kamotors
                • Nov 2007
                • 7102
                #2827
                No I didnt know he had one. I had to guess a bunch and just take curves and get general ideas from other motors like s14 and others. im on 22 revisions so far but its running 100x better after yesterdays tuning.
                7speedshop.com
                • 318aye
                  • Jun 2010
                  • 895
                  #2828
                  I haven't looked at it yet but I think it's just an msq with the tables configured correctly, not actually tuned for an m20. We will see.
                  • downforce22
                    • Aug 2009
                    • 3193
                    #2829
                    My buddy did the pikes peak hill climb in 2012 and he was using an AEM wideband. His friend, who did a build thread on here (username Zodow) for his e30 turbo Hill Climb car the same year, had troubles with the innovate. He switched to the AEM and that fixed the issues. No experience with the innovate, but I've got an AEM one and it has been great for me.
                    • lostbeachbum
                      • 671
                      #2830
                      How is the new RHD flywheel. I have one sitting in the garage waiting to go in and wanted to see if you had any opinion.
                      FS:///M-Tech Wallets.
                      http://www.r3vlimited.com/board/showthread.php?t=224601
                      • Jb325is
                        • 2137
                        #2831
                        You can buy replacement sensors for the innovate at advance/autozone for like $40. The part # is Bosch 17014
                        We used to use Innovates exclusively on race cars and found they are a lot less reliable that the AEM for sure. That and the need for constant re-calibration makes the self-calibrating AEM a better choice. That said, I still have an Innovate, I'd like to upgrade to the LC-2 though, packaging is a bit needer and calibration is easier.
                        - '88 m54 coupe
                        <3
                        • TheTacoMan
                          • Nov 2011
                          • 2308
                          #2832
                          It revs so fast, the down rev sounds noticeably faster than a stock flywheel.
                          • kamotors
                            • Nov 2007
                            • 7102
                            #2833
                            quick down and up revs, no complaints, its not noisy, clutch works like stock, perfect fit. zero complaints only positive for the 7lb flywheel.
                            7speedshop.com
                            • kamotors
                              • Nov 2007
                              • 7102
                              #2834
                              some plug reading since I dont have a wideband anymore...
                              cyl1(the bank with wideband monitroing normally)
                              cyl4
                              cyl5
                              7speedshop.com
                              • whodwho
                                • Jun 2008
                                • 1547
                                #2835
                                Definitely not 'pig rich', more on the too lean side... are these cruise or a hard run and shut immediately off and the plugs pulled? any alum specks?
                                My M20 Frankenbuild(s)
                                4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
