Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #3601
    I didn't measure but just went until it just cleared booster by about 2-3mm. I have condor mounts so hopefully it's enough clearance. It put it high enough that had to cut out a good chunk of the hood skeleton. Even after clearance the metal backing plate with a notch around booster and flattening the bottom of the number 6 velocity stack to get it installed .
    Sent from my SM-N920T using Tapatalk
    7speedshop.com
    • 318aye
      • Jun 2010
      • 895
      #3602
      Oh wow, I didn't have to cut anything on the box or the hood. :???: :???:
      • kamotors
        • Nov 2007
        • 7102
        #3603
        Booster clearance +hood modification
        7speedshop.com
        • kamotors
          • Nov 2007
          • 7102
          #3604
          Re torqued headstuds after my initial heat cycle. Need to build the exhaust system still and paint the alpina valance.
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #3605
            $6 later
            7speedshop.com
            • TheTacoMan
              • Nov 2011
              • 2308
              #3606
              Thats not brown.
              • digger
                • Nov 2005
                • 6195
                #3607
                one of strut tower nuts is loose?
                • kamotors
                  • Nov 2007
                  • 7102
                  #3608
                  2 aren't installed in the pic. I was test fitting a strut tower bar. ebay nor garagisitic bars fit the air box
                  7speedshop.com
                  • kamotors
                    • Nov 2007
                    • 7102
                    #3609
                    7speedshop.com
                    • stonea
                      • 2892
                      #3610
                      The itb's look great!i really want a set, but I doubt they would fit the ix.
                      My Garage
                      Feedback
                      Instagram: Stone.Hopkins
                      • bradnic
                        • Jul 2012
                        • 3554
                        #3611
                        Why do you think that stonea? I'm def game for RHDs on my IX when the time comes
                        HOWTOs:
                        DB vert plastic bumpers
                        OEM Keys
                        MTech1 docs
                        88 ix Lach/Card
                        91 ic Calypso 3.1
                        86 Cosmo 2.7
                        OEM+ or bust!
                        • CarsonE30
                          • Jun 2015
                          • 2124
                          #3612
                          On a scale of yes to no, what about doing an ITB'd and boosted M20? I'll be the donor test car :devil:
                          C6Z
                          S2K
                          VeloN
                          • stonea
                            • 2892
                            #3613
                            I don't have my ix with my 325i to compare the differences, but I know the ix booster is much thicker so it probably pushes the reservoir into where the airbox would be, but there could be room under there and its just the angle of the picture. I'm sure the booster its self will clear since people use it for clearance in 24v swaps. I guess you could do a remote reservoir the more I think about it.
                            My Garage
                            Feedback
                            • bradnic
                              • Jul 2012
                              • 3554
                              #3614
                              Ahh the booster of course. Much smaller diameter but much thicker as you say.. Maybe Rama can chime in
                              HOWTOs:
                              OEM Keys
                              MTech1 docs
                              88 ix Lach/Card
                              91 ic Calypso 3.1
                              86 Cosmo 2.7
                              OEM+ or bust!
                              • kamotors
                                • Nov 2007
                                • 7102
                                #3615
                                I'm willing to bet a smaller diameter brake booster that is a bit thicker would clear the airbox just fine.
                                the booster being thicker wouldnt interfere from what i can see.
                                7speedshop.com
