Kamotors E30-Turbo to ITB M20
  • IronFreak
    • Dec 2012
    • 3702
    #1801
    Originally posted by kamotors
    Better order a new license plate.........
    Instagram @rebellionforge
    • JCarp90
      • Feb 2011
      • 1759
      #1802
      do a burnout
      • kamotors
        • Nov 2007
        • 7102
        #1803
        quick test fit in position 2, will be using position 3.
        7speedshop.com
        • itskingsteelo
          • Jul 2013
          • 1340
          #1804
          Sweet lawdy
          Originally posted by dvck
          • TheTacoMan
            • Nov 2011
            • 2308
            #1805
            With a big turbo at the angle I imagine some more clearance will be needed maybe its just the pictures.
              • 37834
              #1806
              I bet the custom radiator support made that install a lot easier. It's a bitch with it in place!
              Grover Beach, California
              BimmerHeads.com
              • Good & Tight
                • Apr 2004
                • 2057
                #1807
                Oh Yeah..!!! Stuff that thing as far back as you can.
                Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                ____________________________
                E-mail Panayiotisx2@gmail.com
                Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                • Jb325is
                  • 2137
                  #1808
                  What mounts are those again? My position "2" with Otis' mounts was way farther back than that.
                  - '88 m54 coupe
                  <3
                  • RagtopE30
                    • Dec 2010
                    • 1869
                    #1809
                    Yeah, if you didn't have to massage the firewall to get it in you need to push it further back. That's just my opinion.
                    450whp 524 lb-ft 1988 336ic In progress
                    http://www.r3vlimited.com/board/showthread.php?t=250709
                    • kamotors
                      • Nov 2007
                      • 7102
                      #1810
                      these are the 300mm.de mounts and it fit without a single modification. so I will be shoving it as far back as I can.
                      7speedshop.com
                      • Bimmer_man
                        • Jan 2013
                        • 1478
                        #1811
                        Damn nice man. Are you going to drive it around as a n/a till you get your turbo in?
                        Float like a cadillac sting like a Bimmer!:)
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #1812
                          Kamotors 325i Turbo build+M30 build
                          Man I wish I did the removable rad support mine was PITA to get it in. It also looks like you got no room for a radiator haha.
                          1991 318i 4dr slick top
                          Mtech 2 turbo restoration
                          • kamotors
                            • Nov 2007
                            • 7102
                            #1813
                            motor is in, position 3 fits excellent. went to bleed the clutch but it all puked onto the carpet so I gave up for today:(
                            7speedshop.com
                            • Bimmer_man
                              • Jan 2013
                              • 1478
                              #1814
                              sorry to hear about the line bleeding on the carpet but dude amazing.
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                #1815
                                That looks more like it. How much did you have to beat the fire wall? I had to beat the trans well on the top and sides and beat the firewall all the way to up by the battery box.
                                When I beat my firewall I actually cracked it in spots and had to weld it back up Id check for cracks but it could just be cause my car was a rust bucket.
                                when you shorten your shifting arm are you going to be shortening and welding it yourself? I sent mine to TIG welder here on r3v and he did an amazing job.
