Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #2551
    Ah so me thinks you destroyed threads on crank the first time it came loose and because you didnt replace crank it knocked it loose the second time cause the threads cant properly seat. new crank no more problems?
    Yes new crank and flywheel and id likely be good..... but im not going to bother. I should be able to make more than enough selling my m30 stuff to afford an entire e30 to pull a motor out of.
    7speedshop.com
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      #2552
      Nooooo m30 will be so much better your still gonna have to rebuild the m20 and your gonna loose all the torques you had.
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • James
        • Oct 2004
        • 335
        #2553
        I don't post in this thread very often but I do enjoy seeing the updates to your car. I'm pretty bummed you're pulling the m30...
        • kamotors
          • Nov 2007
          • 7102
          #2554
          I do not plan on rebuilding the m20 bottom end, its going to be a simple, performance head, set of itbs, drop it in and drive
          7speedshop.com
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            #2555
            turbo?
            • kamotors
              • Nov 2007
              • 7102
              #2556
              turbo?
              Not turbo, taking a break from boost. I can turbo it or another bmw when I get bored of it.
              7speedshop.com
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                #2557
                ah I see. Well i guess im in for the change of pace
                • Javier h
                  • Sep 2007
                  • 1189
                  #2558
                  Wait
                  Why not a plain m30 without a turbo?
                  You have the m30 in there already and the power band should be plenty unless you are concerned with overheating issues or swap related concerns.
                  • rturbo 930
                    • Dec 2005
                    • 2627
                    #2559
                    Sounds like it might be time to take a step back and focus on something else for a while. Come back to it when you've got a level head.
                    Maybe just swap the M30 for another one?
                    • E30 Beast
                      • Jan 2010
                      • 182
                      #2560
                      Such a sad ending 😥😢
                      • kamotors
                        • Nov 2007
                        • 7102
                        #2561
                        M30 powerband when n/a was terrible compared to a peppy m20. I like revving out high and the m30 is a grunty torque monster that likes to stay between 3500 and 5k. I like revving things out like 2 strokes. I drove several times before the turbo and I was very unimpressed.
                        7speedshop.com
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #2562
                          What rear end you running?
                          • ian e30 318is
                            • Mar 2007
                            • 1809
                            #2563
                            Damn that is shitty! Sorry to see the struggles and frustrations after all the hard work put in.
                            1991 LS1 Swapped 318is
                            Instagram:
                            https://instagram.com/saltybeast/
                            LS Build Thread:
                            https://www.r3vlimited.com/board/for...s-e30-ls1-swap
                            • stanhayward
                              • Mar 2013
                              • 765
                              #2564
                              I have a set of ITBs for an M30 if you change your mind... ;)
                              1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
                              1984 316 Coupe - The Base Model - Pain in the Ass
                              1988 750iL - The Daily Driver
                              ...And a couple others...
                              • kamotors
                                • Nov 2007
                                • 7102
                                #2565
                                Goal Is something similar to this http://youtu.be/Y8tBGppPSTk
                                7speedshop.com
