Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #3421
    7speedshop.com
    • rzerob
      • Jun 2013
      • 2315
      #3422
      17's, so are you going back the fifteen52's?
      • kamotors
        • Nov 2007
        • 7102
        #3423
        No sold those, these new wheels are a bit wider but still not as wide as I'd like. Apex was sold out of the arc wheels I wanted so I just got some cheaper wheels for now. They should be here by the weekend
        Sent from my SM-N920T using Tapatalk
        7speedshop.com
        • kamotors
          • Nov 2007
          • 7102
          #3424
          A bit of therapy...noises I'm lucky enough to enjoy everyday.https://youtu.be/oJr0OfBKkb4
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #3425
            welp solved my grip issues, these ecsta v720 are awesome!, best tires I've run so far.
            [IMG]20160311_162830 by kamotors@y, on Flickr[/IMG]
            [IMG]20160311_162751 by kamotors@y, on Flickr[/IMG]
            did a 0-110pull so much less drama now.
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              #3426
              7speedshop.com
              • delamaize
                • Nov 2013
                • 1460
                #3427
                Originally posted by kamotors
                So chasing a couple of strange issue, now that I have what I consider a lot of grip, I fear the clutch is slipping, if I do a complete 3rd gear pull from 2500-7k the car will get to full boost very fast by about 3800rpms however the car does not start accelerating quickly until I reach around 4800-5000rpms. I thought maybe it was lag but it's clearly at full boost, but power is being lost somewhere.
                To test I did a brake boost pull. I built 15psi at around 3500 around a 40mph roll. Normally doing this launches away like a jet, however when I left off the brake the car just kind of made a strong chatter and vibration(similar to a bad guibo) and once I reached closer to 5k then it just flew away, but I had full boost for close to 2k rpms and the car didn't pull hard. AFR is spot on, boost is fast and reaching target.
                The rpms are not climbing like a slipping clutch so I'm pretty stumped. If I ease into boost the car is faster. If I run threw the gears power is fine, it's only lugging into a gear that is resulting in a full boost lack of power situation and into and only happens in gears 3-5. Second gear has power as soon as boost hits.
                Summary-going all out isn't making power like easing into boost at part throttle does. Possibly slipping clutch from how hard boost hits. Also throttle leaks...
                Are you still running a single plate clutch? I wounder of a double plate might fix the slipping issue....
                Dumpster Fire Pilot
                • ak-
                  • 12422
                  #3428
                  Don't tell me this - I was very soon going to get the same clutch :^(
                  I have that same chatter problem too when I'm full boost in 4th - feels/sounds like a bad driveshaft (mine is new). I thought it was the clutch not holding up as well considering mine slips in hard 3rd/4th pulls but never in 2nd.
                  1991 325iS turbo
                  • kamotors
                    • Nov 2007
                    • 7102
                    #3429
                    , it's the only thing I can think of. I'm thinking the chatter/vibration is the clutch repeatedly just barely slipping in till it catches at higher rpm. Not enough to have rpms shoot up a bunch but enough to notice power not going to the wheels.
                    7speedshop.com
                    • ak-
                      • 12422
                      #3430
                      It bothered me enough to finally tend and poly' bush:
                      Subframe bushings
                      TA bushings
                      Diff bushing
                      RSM's
                      Axles
                      Driveshaft / flex disc / CSB
                      It is still there, so last thing to replace is the slipping clutch. I'm just conflicted what to get considering I don't really want a chattery clutch anymore.
                      1991 325iS turbo
                      • kamotors
                        • Nov 2007
                        • 7102
                        #3431
                        Subframe bushings
                        TA bushings
                        Diff bushing
                        RSM's
                        Axles
                        The only other clutch I'm seeing that'll affordably hold the power is like a spec stage 5.
                        7speedshop.com
                        • TheTacoMan
                          • Nov 2011
                          • 2308
                          #3432
                          I haven't gotten my spec stage 3+ to slip yet, but it feels like poo poo to drive, very knife edge feel.
                          • kamotors
                            • Nov 2007
                            • 7102
                            #3433
                            At the local motorsport expo.
                            7speedshop.com
                            • kamotors
                              • Nov 2007
                              • 7102
                              #3434
                              So likely doing a part out of the E30. My father passed away last week and Now I've got to take care of my 2 younger brothers and help pay mortgage and medical bills for my mother.
                              I'm doing a partout because I dont want to sell the entire car and I'd rather just sell the parts that are worth $$$.
                              So full turbo kit will be for sale, only have like 6k miles on it. I have an M30 5 speed and and M20 5 speed for sale as well. PM me if you interested in the entire turbo kit, it makes 400whp very easy.
                              7speedshop.com
                              • Kershaw
                                • 11822
                                #3435
                                I'm very sorry to hear that.
                                AWD > RWD
