Kamotors E30-Turbo to ITB M20
  • Denny
    • Jan 2010
    • 822
    #721
    Originally posted by kamotors
    a pic from the drive today at lest it was purdy before it died.
    ahhhh man that really sucks. I know this car will be back much stronger!
    Something tells me am going to be rebuilding a M20 very soon too...lol..
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
      • 37832
      #722
      Can't wait to get one of our heads on this thing!
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • kamotors
        • Nov 2007
        • 7102
        #723
        my catchcan was full of poo in only 2 drives and it was going into my exhaust and boiling. Here is the broken rocker. My oils are NOT mixing in the motor or in the radiator. headgasket is still holding, just other issues. which could of happened N/A.
        7speedshop.com
        • Cronopoulos
          • Jul 2011
          • 2187
          #724
          What was your r3v limit at? I can't believe you're still good on you HG, goes to show you what a good tune can do.
          Project log -- DIRTY 30
          2.7i * Megasquirt tuned * E85 powered
          • kamotors
            • Nov 2007
            • 7102
            #725
            revlimit at 6800
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              #726
              so I'm going to be running a different manifold that I will modify and I was wondering if this wastegate location i'll be adding in looks like it would work well.(wastegate port not to scale)
              7speedshop.com
              • FLG
                • Sep 2011
                • 3165
                #727
                Imo looks like it might be a bit too close to the downpipe
                Sent from my Galaxy Nexus using Tapatalk 2
                -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                • darvo
                  • Dec 2010
                  • 407
                  #728
                  Where was your 2-step set to?
                  • Cronopoulos
                    • Jul 2011
                    • 2187
                    #729
                    Kameron, is that split pulse? Can you mod a pipe off each collector and run dual 44mm wastegates?
                    • JCarp90
                      • Feb 2011
                      • 1759
                      #730
                      well I hit the revlimiter like 6 times today drifted multiple corners and was running around 21-22 psi. it was to be expected I guess:) time to build it up better I get tax return in march so that's when the rebuild will begin.
                      This is awesome. I wish I had this attitude whenever I break my shit lol.
                      • darvo
                        • Dec 2010
                        • 407
                        #731
                        Thats what I'm going with, with mine.
                        • FLG
                          • Sep 2011
                          • 3165
                          #732
                          Unless it was modified that's not a split pulse manifold.
                          • kamotors
                            • Nov 2007
                            • 7102
                            #733
                            not a split pulse, it combines right in the red area I marked, I've been examining the manifold in person and it seems like It may favor 3 cylinders when just placed to the side but I'm not sure it would cause creep issues.
                            also that picture is like flipped the wrong way the turbo would be at the front and the wastegate provision would be facing the opposite way of the downpipe.
                            7speedshop.com
                            • Cronopoulos
                              • Jul 2011
                              • 2187
                              #734
                              Looks like a solid setup, yeah i noticed it was flipped. Are you having creep issues now?
                              • kamotors
                                • Nov 2007
                                • 7102
                                #735
                                I'm having zero creep issues, only changing manifold to get the turbo to sit higher up in the bay so I can route piping different.
                                7speedshop.com
