Kamotors E30-Turbo to ITB M20
  • Cronopoulos
    • Jul 2011
    • 2187
    #736
    Originally posted by kamotors
    I'm having zero creep issues, only changing manifold to get the turbo to sit higher up in the bay so I can route piping different.
    Ah, sweet! Can't wait to see what's to come!
    Project log -- DIRTY 30
    2.7i * Megasquirt tuned * E85 powered
    • ak-
      • 12422
      #737
      I wonder if anything would change considering the collectors are different.
      Could you update if there is any at all?
      1991 325iS turbo
      • kamotors
        • Nov 2007
        • 7102
        #738
        I'm guessing powerband will shift due to the MUCH longer equal length manifold, but I really wont be able to tell what the manifold caused because i'm also going to be running a cam that will further change the power band at the same time.
        7speedshop.com
        • barbierij
          • Sep 2012
          • 1294
          #739
          Would you be interested in selling your current manifold? I just bought my megasquirt to start my turbo project on my '90iX
          FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
          Saab/GM tech2 programming
          My for sale thread
          1990 325iX for sale or part out
          Did you buy something from me? Please leave feedback!
          Originally posted by K20RI_211
          And I have to ask if you make a hobby out of thread-bombing with retarded questions?
          • kamotors
            • Nov 2007
            • 7102
            #740
            yup, I'm selling my current wastegate and manifold.
            I already have a tial MVS on the way
            7speedshop.com
            • barbierij
              • Sep 2012
              • 1294
              #741
              sorry to hear about the engine man. I never broke a rocker but the timing belt broke on the '89iX around 170k. That was before we knew what this car really was and what it needed. What would you want for the manifold and wastegate? I'm also a Mr eBay and I have been looking at the CXracing manifold with turbo and downpipe kit.
              My for sale thread
              • ak-
                • 12422
                #742
                What if you connect both individual banks into 1 wastegate provisional?
                Maybe enough to avoid creep? Or is it kind of a moot point since it still has to go through 1 wastegate port anyways.
                1991 325iS turbo
                • kamotors
                  • Nov 2007
                  • 7102
                  #743
                  connecting both would work, but probably not any better than just popping the provision right in the middle. Both pipe ARE merged in the few inches below the turbo flange so I dont think creep will be an issue as long as the wastegate tube is angled to flow correctly.
                  also I am fine with minor creep towards redline because i was going for a flat torque now anyway. I'm think 15psi and raising to around 17-18 by redline.
                  The rebuild will move the focus of my car from just trying to get a high WHP number to trying to get an amazing power band that last more than 1k rpms.
                  I'm planning on revving to at least 7200rpm with the new cam.
                  7speedshop.com
                  • FLG
                    • Sep 2011
                    • 3165
                    #744
                    That sounds like a plan.
                    With my setup, have a absolutely flat band that pulls all the way to red line.
                    Sent from my Galaxy Nexus using Tapatalk 2
                    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                    • kamotors
                      • Nov 2007
                      • 7102
                      #745
                      is there anything wrong with leaving the accessory pulley off of the lower crank pulley? I dont have A/C and I'm removing power steering. any reason not to leave it off?
                      7speedshop.com
                      • TheTacoMan
                        • Nov 2011
                        • 2308
                        #746
                        Less weight faster revving? Why not?
                        • u3b3rg33k
                          • Jan 2010
                          • 2452
                          #747
                          What rear brakes are those? that's where my Wilwood handbrake caliper goes.
                          Ich gehöre nicht zur Baader-Meinhof Gruppe
                          Originally posted by Top Gear
                          Just imagine waking up and remembering you're Mexican.
                          Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
                          • kamotors
                            • Nov 2007
                            • 7102
                            #748
                            stock, just missing subframe so sitting at weird angle.
                            7speedshop.com
                            • u3b3rg33k
                              • Jan 2010
                              • 2452
                              #749
                              LOL derp. thanks.
                              The only important parts are the 60-2 wheel & harmonic damper - everything else can go (well, i suppose the water pump / alternator drive pulley matters a little bit).
                              • Cronopoulos
                                • Jul 2011
                                • 2187
                                #750
                                LOL derp. thanks.
                                What about stock "balance" of the motor, that's what im curious about.
