Kamotors E30-Turbo to ITB M20
  • Denny
    • Jan 2010
    • 822
    #871
    yeah first time i did with head on,just do one at a time starting in the OEM torquing order.
    so remove number 1-replace w/ stud,tighten, remove 2 and replace w/stud,tighten and so on, works just fine without issue.
    Cool! thanks. So tighten each one to 60-70 pounds one shot no steps and no waiting?
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
    • kamotors
      • Nov 2007
      • 7102
      #872
      I did it to a good 60ft-lbs first pass and then went back and did 65ft-lbs then heat cycled for a good 10minutes and did another re-torquing at 65ft-lbs. you'd be surprised how much some of them loosen after a heat cycle.
      7speedshop.com
      • kamotors
        • Nov 2007
        • 7102
        #873
        A quick video from today just driving around.
        7speedshop.com
        • Denny
          • Jan 2010
          • 822
          #874
          so at 19psi now, need to retune desperately at high loads, hit 10.9AFR and bogged during 3rd gear and still made 425rwhp on virtual dyno.
          and guess it was a bad idea to get groceries with turbo E30.
          via Imgflip Meme Generator
          LOL... now tell us the real story.
          goes like this...because you have no back seat and Tacoman really really wanted to ride along and camera man was already in the front seat.... when you got home from the drive you open the trunk and Taco jizzzed all over with full of love for the kamturbo30... LOL LOL...
          Denny
          ___________
          Blogs:
          • TheTacoMan
            • Nov 2011
            • 2308
            #875
            Hahaha, nope.
            • Peattie
              • Apr 2013
              • 260
              #876
              • kamotors
                • Nov 2007
                • 7102
                #877
                Dat Rasp:) quick outside video of me not getting traction lol
                7speedshop.com
                • Cronopoulos
                  • Jul 2011
                  • 2187
                  #878
                  That underpass has a few black lines on it now ;)
                  Project log -- DIRTY 30
                  2.7i * Megasquirt tuned * E85 powered
                  • kamotors
                    • Nov 2007
                    • 7102
                    #879
                    many black lines:)
                    also turned down the boost 1psi and cleaned up the tune so I should make the same power on a cleaner tune. The higher boost gets harder to clean up because the map is pretty low resolution and makes little fine adjustments hard.
                    but I did it with a virtual dyno tune so its should be pretty dialed in.
                    7speedshop.com
                    • Myster-E
                      Performance
                      • 552
                      #880
                      It just keeps getting better and better! Great work kameron!
                      1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
                      Visit www.BimmerHeads.com for all of your 12 valve needs!
                      • Cronopoulos
                        • Jul 2011
                        • 2187
                        #881
                        many black lines:)
                        Can you add a second VE map to take advantage of everything above 100 kpa (map switching i think they call it)?
                        • kamotors
                          • Nov 2007
                          • 7102
                          #882
                          not sure how.
                          today I setup EGO control, I've been driving without it for some time and got cruising dialed in but now with it on it can help get a nice steady AFR and have less issues with heat soak and MAT correction since MS will now actively dial in little changes to the fuel map to help maintain the AFR.
                          7speedshop.com
                          • Cronopoulos
                            • Jul 2011
                            • 2187
                            #883
                            not sure how.
                            Me either but it sounds cool!!! EGO FTW!
                              • 37832
                              #884
                              Making some SERIOUS power with this car now Kam.
                              Are you coming to Bimmerfest by chance?
                              Classic BMW Specialists
                              Grover Beach, CA
                              www.BimmerHeads.com
                              • kamotors
                                • Nov 2007
                                • 7102
                                #885
                                probably not making bimmerfest:(
                                7speedshop.com
