The timing map is incredibly critical for transient response and spool. Get your timing dialed in and the car will feel much better!
					Kamotors E30-Turbo to ITB M20
 Well injector tick is considered normal. It's probably more apparent to you now because you are actually trying to notice it this time around.Originally posted by kamotorsalso I seem to of grown a ticking fuel injector, I listened around for a good 10 minutes under the hood and it doesn't seem to be coming from the valves, its a slower tick. noise does not increase with oil cap off.
 is it something to worry about? car runs fine.
 Take a stethoscope to it and confirm.
 Sure its not a manifold leak? Something that's louder in cold climates (NV??)Comment
 I double checked the manifold and it seems to be sealed nicely, if its valve tick it sounds as if its only one valve out of adjustment becasue of the speed of the tick. It may just be that I'm hypersensitive to noises since i have all this hard work dumped into the car.
 seems to be coming from the very rear of the VC/ fuel injector area, I can only hear it below 2krpms.
 7speedshop.comComment
 Hypersensitive! That's the word I was looking for. I'm the same way, lol.I double checked the manifold and it seems to be sealed nicely, if its valve tick it sounds as if its only one valve out of adjustment becasue of the speed of the tick. It may just be that I'm hypersensitive to noises since i have all this hard work dumped into the car.
 My small manifold leak goes away above 2krpm. Maybe other noises cancel it out + heat.
 If the engine is cold, and permits my hand being millimeters close, I can feel the pinhole leak out of the manifold.Comment
