Kamotors E30-Turbo to ITB M20
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #2371
    I know where one is but its not "new" and i could get it for cheap
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • jim325
      • 228
      #2372
      I have one that I just bought from Todd at TCD. He said it works fine. I didn't get to install it. I replaced the rear output seal and realized the output shaft is different size than the current G260 I have... It's about 2 inches longer, maybe a bit more. Comes with an extended output shaft flange, but then I would either have to really get my DS shortened or move the engine farther forward, but then it would eat the radiator.
      If it sounds like one that might work for you let me know. I bought it for $300 so that's what ill take for it, plus shipping. I can take a picture if your interested.
      89 325i: 86 535i motor+trans, JE forged pistons, MLS head gasket, ARP head studs, Comp turbo, GoodNTight b34 turbo manifold, e30.de motor mounts, AKG 75D engine/trans mounts, custom 3" exhaust, intercooler, MS2PNP, Megan Racing Coilovers.
      • LJ851
        • 7919
        #2373
        Does the noise and vibration go away when you disengage the clutch ?
        Lorin
        The M30 is God's engine.
        • kamotors
          • Nov 2007
          • 7102
          #2374
          it lessens greatly. video is uploading now, rattle somewhat goes away at 2k but I can feel the rattle in the clutch pedal.
          7speedshop.com
          • Good & Tight
            • Apr 2004
            • 2057
            #2375
            Possibly the clutch fork is loose and rattling around.
            Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
            ____________________________
            E-mail Panayiotisx2@gmail.com
            Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              #2376
              ^ that or pressure plate
              • kamotors
                • Nov 2007
                • 7102
                #2377
                how would the pressure plate be causing that kind of rattle?
                7speedshop.com
                • Bullet Ride
                  • Dec 2010
                  • 598
                  #2378
                  If it goes away when you press the clutch in I'd say throw out bearing.
                  • Good & Tight
                    • Apr 2004
                    • 2057
                    #2379
                    Well after listening to the video, tranny has to come out either way.
                    • LJ851
                      • 7919
                      #2380
                      The fingers of the pressure plate should all be at a uniform height so when they spin, the throw out bearing sees a constant surface. If the fingers are not uniform in height, as the pressure plate rotates it wobbles the fuck out of the throw out bearing on the guide tube and shakes the throw out arm which transmits to your clutch pedal.
                      Worn input bearings usually rumble more than rattle like your sound. I bet money on it being in the clutch and of course otis is right, engine and trans must separate one more time.
                      Lorin
                      • kamotors
                        • Nov 2007
                        • 7102
                        #2381
                        so why would my pressure plate go bad all of a sudden? cant afford another clutch lol
                        7speedshop.com
                        • LJ851
                          • 7919
                          #2382
                          The Hand of God (aka M30turbo) twisting on it.
                          Lets hope it's something else cheaper like a fragged TO bearing...
                          Lorin
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #2383
                            This^.. If it's the clutch I'd give up and make Otis's clutch setup but that's just me.
                            • itskingsteelo
                              • Jul 2013
                              • 1340
                              #2384
                              STR518 17x9 et 22 rear, 12mm spacer on the front so et10 front.
                              They weigh 19lbs so getting a bit heavy but for a 17x9 not so bad.
                              Just wondering, i have the same wheels 10mm spacers up front and 12mm in the back but i have to stretch my tires so they dont rub.
                              How are you running square tires?
                              Im asking because i might switch wheels and go with something wider in the future.
                              Originally posted by dvck
                              • TheTacoMan
                                • Nov 2011
                                • 2308
                                #2385
                                Lots of cutting and fender flares, 17x9 up front rub for me even then. Not sure if Kamerons is different.
