Kamotors E30-Turbo to ITB M20
Denny
___________
1990 BMW red 325IC M30B35 all stock Girlfriends ride
1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
Blogs:
http://bmw325e30.blogspot.com/ (restoration)
http://bmw325e30turbo.blogspot.com (Twincharge M20)
http://bmw325e30m62b44.blogspot.ca/ -
Awesome pics man! beautiful car!! said it before and I will say it again....damn lucky bastard for having all those 30's local to you.Denny
___________
Blogs:
http://bmw325e30m62b44.blogspot.ca/Comment
You should definitely go on a drive with us next car show. A guy in a bronzit early model drove by with a r3vlimited sticker. Then left instantly.Comment
here are my specs, how much sooner would a gt3076r spool?
HORSE POWER: 300-550 HP
COMPRESSOR COVER SIZE : 60 SERIES
INTAKE : 4" INCH
INLET : 3" INCH
H-61 COMPRESSOR WHEEL
COMPRESSOR WHEEL DIAMETER: 61.41 / 81.99 mm
F-157 TURBINE WHEEL
TURBINE WHEEL DIAMETER : 64.89 / 62.07 mm
TURBINE HOUSING AR : 65
TURBINE FLANGE : T3 4 BOLT / 3" V BAND EXHAUST
COOLING TYPE : DRY HOUSING ( OIL COOLED ONLY)
Item(s) Specification :
- 4" Air Inlet
- 2.5" Compressed Air Outlet
- Ceramic Ball Bearing on Compressor Side Compressor
- Standard T3 Turbine Housing Flange
- 4 bolt 3" Exhaust Outlet
- 400-600 HP
- Oil /Water Cooled
- Working Pressure: 8-30 PSI
- 0.70 A/R Compressor
- 0.63 A/R Turbine
- Compressor Wheel (Major/Exducer): 71/53mm
- Turbine Wheel (Major/Inducer): 68/62.3mm
7speedshop.comComment
No one makes this car anymore. The government won't allow them, normal people won't buy them. So it's up to us: the freaks, the weirdos, the informed. To buy them, to appreciate them, and most importantly, to drive them.Comment
Got to get that power band more meat, peak horsepower isnt always faster. A smaller turbo, spool sooner, more power sooner and just as much top end.
