Ford 5.0 swap into a Bronzit. Update: Now running, VIDEO ADDED.
  • Exodus_2pt0
    • 5943
    #46
    Fleetpride. I was afraid they wouldn't shorten an aluminum unit, but they didn't flinch when I called.
    No E30 Club
    • IronFreak
      • Dec 2012
      • 3702
      #47
      yeah, I have an inland right behind my house. Where did you get the aluminum drive shaft?
      Instagram @rebellionforge
      • Exodus_2pt0
        • 5943
        #48
        Out of the donor car.
        I need to have it looked at anyway, a little bit of rub damage from something under there. The owner of the Mustang is planning on having a whole new one made.
        No E30 Club
        • Exodus_2pt0
          • 5943
          #49
          Just measured the damage, its a little less than 1mm difference from the area that rubbed to the rest. I'm hoping that is acceptable, but I have no idea how thick the tubing is.
          No E30 Club
          • IronFreak
            • Dec 2012
            • 3702
            #50
            Run it, if it breaks make a new one!
            • Exodus_2pt0
              • 5943
              #51
              It was working fine in the Mustang, no vibrations.
              Upon closer inspection, the gouge is .023in deep. I'm thinking about just asking if the shop can remove that section when they shorten it. Knock out 2 birds with one stone.
              No E30 Club
              • chance
                • Feb 2012
                • 671
                #52
                That would work.
                My steel one was 40 to shorten, so I think 100 is pretty good for aluminum
                1991 335is in progress
                • Exodus_2pt0
                  • 5943
                  #53
                  Dropping off the driveshaft in the AM, called the shop and they said it should be OK.
                  Got the throttle cable situated! Couldn't have been easier. I took the stock one out of the Mustang, turned the hole that the E30 cable goes through 90*, cut a slice out of it and closed up the hole a bit, fit the Mustang cable perfectly. Perfect length too, I just hope I can keep this EASY momentum up.
                  Although, the clutch is bothering me. I was hoping to save money by running the cable clutch setup that is in the Mustang now. It has some crazy pulley on the clutch pedal that makes it feel like a hydraulic. I just don't know if I will have room for the mustang pedal set under the dash. I may just have to fork over the cash that I don't have for a hydraulic slave conversion on the T5.
                  No E30 Club
                  • eurotrash
                    • May 2007
                    • 768
                    #54
                    Theres a $70 slave setup in one of the swap threads floating around somewhere. DONT i repeat DONT swap to a cable. Mine has a custom cable pully setup and i hate it sooooo much. Its not as bad now that ive got a legit pully inthere but the cable was breaking like every 4-5 drives. Annoying as shit. You also have to do a custom cable legth and have a very very good hand held cable swedge tool or use the shitty cable lock u bolt thingys. I lucked out and my dad had the swedge tool but its a pain in the ass.
                    If youve got your heart set up running cable ship me your stock pedal cluster and ill ship u mine.
                    • Exodus_2pt0
                      • 5943
                      #55
                      I think I'm going to stick with hydraulic.
                      Just need to figure out which slave to use. Looks pretty simple to fabricate a bracket out of some angle iron.
                      No E30 Club
                      • Exodus_2pt0
                        • 5943
                        #56
                        Found that thread. Early 81 280z slave. For $13 its worth a shot.
                        No E30 Club
                        • eurotrash
                          • May 2007
                          • 768
                          #57
                          Theres an actual kit for $70.
                          • eurotrash
                            • May 2007
                            • 768
                            #58
                            Here ya go look down the page you see the hydralic conversion mount think it was listed at $76
                            Emailed him about a generic t5 kit(slave slave mount pushrod and line) we'll see what he says.he has early mustang kits listed but hopefully he can get us setup with something without the fancy ofset pushrod and mc stuff.
                            Also i left a link on the 5.0 swap faq i did for the wilwood pedal setup that mounts at stock location. It'll make the entire thing like $700 or something with the slave and pedals but it'll all bolt in and there will be no jerry rig stuff goin on. I know one the distributor is replaced along with some chassis bushings this is the next thing ill be looking at buying.
                            • E30Jigzaw
                              • 1197
                              #59
                              This is getting more and more popular !! I would love to do something like this but don't have a time or space :/ great project major props!!
                              Buy e30 cup holders
                              http://www.r3vlimited.com/board/show...41#post4159541
                              Buy BMW Motosports handles
                              http://www.r3vlimited.com/board/showthread.php?t=302846
                              Buy BMW MOTORSPORT valve covers http://www.r3vlimited.com/board/showthread.php?t=330146
                              • Exodus_2pt0
                                • 5943
                                #60
                                Just picked up my driveshaft and registered! I'm so close I can taste it.
                                No E30 Club
