euro early 318i - blew M10, swapped another one, M10B2035cc NA ITB build
  • Mirek E.
    • Sep 2013
    • 105
    #76
    Did another job on car. Painted struts and new Ate rotors and pads.
    318i M10 '87
    • tak7
      • 856
      #77
      Beautiful car, keep up the good work!
      • Mirek E.
        • Sep 2013
        • 105
        #78
        After few weeks of snowy and rainy weather, today weather was excellent. So, why not wash the car and take some pictures? :)
        318i M10 '87
        • Matt341
          • Feb 2014
          • 358
          #79
          Amazing work here really inspiring. Love the car!
          Bmw CCA # 490080
          1995 525iA RIP
          1987 325e Cirrusblau-Metallic/Pacific Blue (Daily)
          DSC_1725 by Matthew Johnson, on Flickr
          • Mirek E.
            • Sep 2013
            • 105
            #80
            Thanks you. :)
            Finally fitted the recaros in car. They are perfect. No more pain in my back.
            Also bought one center cap for cheap. :)
            318i M10 '87
            • Mirek E.
              • Sep 2013
              • 105
              #81
              Little update here.
              I did conversion from bolts to studs and nuts.
              Before installation I cleaned threads in bearings from grease and secured them with thread locker.
              Also installed rear poly bushings.
              Found real Nardi FI350 steering wheel for really cheap price. That guy had no idea what Nardi brand is. He sold it to me for 20 bucks. Bought cheap hub for e30 with nardi bolt pattern and throwed it in to the car. It's little bit smaller in diameter than original 4-spoke bmw wheel, but comfort while driving is much higher because it's thicker and feels better in hands.
              Horn is from momo wheel.
              And for the end, yesteday I bought new heart.
              It's M10B18 with Pierburg carb and 9.5:1 compression ratio. Want to buy catcams sport cam, itbs, do some head work, aftermarket ecu... But first of all I need to do overall inspection of the engine, main bearings wear, cylinder walls... But I hope it will be a monster. :D
              318i M10 '87
              • econti
                • May 2014
                • 1102
                #82
                Every damn time I see that paint I want to get mine repainted
                • Mirek E.
                  • Sep 2013
                  • 105
                  #83
                  Painted front and rear windshield trim black, it wasn't chrome anymore.
                  Also collected almost all parts for drivetrain refresh. There is a new Ferodo Ceramic unsprung clutch disc with Luk pressure plate and thrust bearing, Swag drive shaft center bearing and Febi seals. Waiting for shift linkage bushings, spacers etc.
                  And for the end, last night photo from small square in city.
                  318i M10 '87
                  • Mirek E.
                    • Sep 2013
                    • 105
                    #84
                    Rear axle out again... Did rear bearings. Never before did worse work than changing rear bearings on an e30.
                    They started be very loud and in one wheel was little play.
                    Today I started to tearing down this old 4 banger. Now its ready for hot steam cleaning.
                    Piano top pistons. 9.5:1 CR stock. With -0.5mm lowered engine block and resurfaced head I hope in 10:1 CR or little bit more.
                    Hone in cylinder wallls is still pretty good. Engine must have low mileage.
                    When it will be cleaned, I remove rods and crank, inspect main and rod bearings, eventually buy new STD, install new piston rings and put it together with all new seals. Then head...
                    318i M10 '87
                    • Mirek E.
                      • Sep 2013
                      • 105
                      #85
                      This weekend I again did a lot of things on car. There is a new center bearing on driveshaft, exhaust rubber mount, bushings, washers and o-rings on shift linkage (with ebay shortshift), changed all plastic clamps on door trim and painted valvecover black.
                      Here are some photos.
                      After one year...
                      M10 beast :)
                      All done
                      And photos from evening drive...
                      318i M10 '87
                      • varg
                        • May 2014
                        • 3318
                        #86
                        Your car looks great, even the engine bay is nice. What's the color called? I've always liked a nice rich blue and that one is very easy on the eyes.
                        IG @turbovarg
                        '91 318is, M20 turbo
                        • Mirek E.
                          • Sep 2013
                          • 105
                          #87
                          Thanks. Color is Aston Martin viper blue mica.
                          Today I changed master cylinder, but I am not very happy with result. When I press brake pedal, it starts braking immediately, but pedal has long travel from low braking power to maximal power. With old cylinder it brakes well, but sometimes when I step on pedal, it was soft and went to the floor without any braking power. Now it's okay, but I don't like that travel of pedal. Any solutions?
                          318i M10 '87
                          • varg
                            • May 2014
                            • 3318
                            #88
                            First step is always to double and triple check the bleed. After that the question is: is the master cylinder the same as before? If you somehow wound up with a master cylinder with a smaller bore it would give you more travel, less effort, and higher pressures.
                            IG @turbovarg
                            • Mirek E.
                              • Sep 2013
                              • 105
                              #89
                              Problem solved. Old drums had too much wear. Bought new and pedal is okay.
                              Today I made longer shifter. I have shortshift from ebay and it was too short. I can't pull out reverse gear by one hand...
                              Now is gear change much easier but it's still shorter than stock shifter.
                              318i M10 '87
                              • Mirek E.
                                • Sep 2013
                                • 105
                                #90
                                Yesterday I changed all old seals on intake manifold. Engine now run much smoother and has better throttle response. Also painted intake black.
                                Engine: https://youtu.be/EZhL_SGq90c
                                Throttle response: https://youtu.be/npXKplMJ-pk
                                318i M10 '87
