euro early 318i - blew M10, swapped another one, M10B2035cc NA ITB build
  • 2mAn
    Señior Mod
    • 20377
    #121
    Originally posted by Mirek E.
    Car is now much better, engine have nice throttle response and it sound totally different. My engine had lower compression from factory, because it's version with catalytic converter, this "new" engine is catless version with higher comp ratio.
    Complete swap costs me circa 300 bucks and it was very worth it. :)
    I am happy how it runs now.
    So, car is in perfect working condition. :)
    This is a great thread. I will have to go through the entire thing soon. I look forward to the M10B20 build too... 2035cc could still be considered 2L IMO haha
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • Mirek E.
      • Sep 2013
      • 105
      #122
      Oh yeah, first plan was 92mm bore, but lately I changed my mind and went only with 90mm. I want it as reliable as possible and don't built engine with short lifespan. 92mm bore and 144mm rods will be much better, but not now. Maybe next time. ;D
      Alex18i: You mean horzintal baffle from Massive? Yeah, it's really worth it. Since I hooked up oil pressure gauge, I can see oil pressure drops in corners. With IE crank scrapper, horzintal and vertical baffle, I never had oil pressure drops/starvation anymore.
      Everyone with M10 in E30 should do this to prevent all problems due to oil starvation. Lower oil pan is empty, there is nothing to stop oil from flowing away from oil pickup. And weld two tabs and bolt in stock S14 baffle with rubber flap is job for 2 hours.
      A few days ago I received the best message from my friend. My pistons from IE, together with coated bearings and chromoly retainers are on the way to Czech Republic. :)
      So, build will continue soon. With nice shiny parts.
      318i M10 '87
      • Mirek E.
        • Sep 2013
        • 105
        #123
        Oh noo, it's almost a year from the last post. Time fly really fast... So, it's time for another update. Due to work and life changes, engine build isn't going as fast as I wanted, but it's still alive. :)
        Season is ending, temps go down here in Europe. Made ~10k kms on "new" engine without any issues. Runs strong, no oil consumption, everything works nice. Scored nice M10B18 engine.
        But more important thing. New engine have some updates. In the end of last year I received pistons from IE. A few weeks after New Year I brought it all to local engine builder and machinist.
        Block is bored to 90mm. Crank and rods measured, all looks good and It's in spec. Bottom end is assembled.
        Assembled bottom end. IE Ross Racing 90mm 11.5:1 pistons, FCP Engineering 135mm H-Beam rods, 2.0 crankshaft.
        Crankshaft, front pulley, flywheel and pressure plate is together balanced to 1 gram. So engine should run smooth, no vibrations etc.
        Aluminium pulley with trigger wheel.
        Custom made exhaust header. Used on M10B20 with 10.5:1 compression, 292 cam and Weber carbs. Engine made 170hp.
        And now the best.
        Dbilas intake manifold, custom ITBs, AE86 stacks...
        I already have new flanges for stacks, so they now fits perfectly.
        I post more pics after get my Flickr account back. I can't log in because they have some problems with migration from Yahoo... So that's all for now. :)
        318i M10 '87
        • econti
          • May 2014
          • 1121
          #124
          That's going to look and sound awesome once together
          • wworm
            • Dec 2016
            • 1719
            #125
            did you use a crankshaft from a 2002?
            1984 Delphin 318i 2 door
            • Mirek E.
              • Sep 2013
              • 105
              #126
              I've got my flanges done by local machine shop. Fits nicely. Now I need to visit my friend with TIG welder a get it spot welded just for securing it in place.
              I also started conversion from drums to 325i rear end with brake discs. Got it almost done, everything is new.
              And yes, crankshaft is from 2002. I bought it from guy from Estonia. It's in nice condition, STD bearings.
              318i M10 '87
              • digger
                • Nov 2005
                • 6018
                #127
                good to see some more NA builds. is that an alloy toothed wheel? do they need iron?
                • gnmzl
                  • Jun 2012
                  • 204
                  #128
                  As I understand it, the pulley itself is alloy and the toothed wheel bolts on to the back of it utilizing some slotted holes for adjustment. Pictured 8, 9 and 10 in post #123 lead me to believe so.
                  OP, I really need to know where you got hold of this toothed wheel, or if you had it locally made, can you get 1 or 2 more?
                  '85 Alpine Weiß 2-door with m20b30 ground up build
                  • CorvallisBMW
                    Long Schlong Longhammer
                    • 13039
                    #129
                    Very cool, I can't recall seeing an ITB'd M10 on here before. Looking forward to more! 6.3.6
                    • 2mAn
                      Señior Mod
                      • 20377
                      #130
                      Loving this build, PM sent!
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      • Mirek E.
                        • Sep 2013
                        • 105
                        #131
                        I made some progress since last post and here are a few photos...
                        Firstly, I ran into a problem with my build.
                        I already ported and matched head with Dbilas intake. Here is everything okay. But when I was about to pack the head and send it to my machinist for new valve guides and cutting new angles on seats and valves, I found a problem with valves. Old guides are so much worn, that they destroyed valve stems too... So I am actually trying to source a new valves and also guides for continuing in build. I really like oversize intake and exhaust valves from Ireland Enginnering, but postage and import charges costs more than parts... (IE want's 167$ for postage, which is absolutely ridiculous. I bought heavier and bigger parts from USA and never paid so much for postage...) So I am actually waiting for reply from EU dealer of VAC parts, since they also offer oversize stainsless steel valves.
                        You can see the sharp edge on stem. You can feel it with nail, so garbage.
                        And here is some junk I bought. Heads locally, crank is from Finland. Another M10B20 crank in collection. :)
                        And lastly
                        That's all for now. See you next time. And also, Merry Christmas and Happy New Year.
                        318i M10 '87
