1971 BMW 1600 Project
  • rturbo 930
    • Dec 2005
    • 2629
    #301
    That looks too clean to part out :(
    • phreshkid
      • 4655
      #302
      Originally posted by LJ851
      When you do this swap, try to use a 3 bolt output flange on the trans and driveshaft, the guibos last way longer in my experience. You have to shorten the drive shaft any way and i think your parts car should have the correct flanges.
      The 3 bolt guibo is slightly thinner so pay attention to correct driveshaft length when shortening.
      You are correct. I've come across this situation with the 74 euro tii I did a 5-speed swap to.
      Being as this is an 82 320iS, it likely has the Getrag G240, not the G245. The G240 is shorter than G245, so I will have to triple check distance between the guibo and diff mating surface.
      Originally posted by dirty30
      Another E21 on deathrow. Sad.
      Circle of life. All give some, some give all.
      It's pretty beat, actually. dents all over the place, interior is torched, and missing a bunch of parts. It "runs" but no where near a level you'd be comfortable with. PO also removed the catalytic converter and put a straight pipe. Not to mention $400 of registration back-fees that I don't care to pay.
      It's a parts car, I'm giving it a good death.
      Besides, after I sell the diff, seats, and wheels, I'll have $0 into it. I didn't pay asking price...not even close.
      • LJ851
        • 7919
        #303
        I was later thinking it might be a 240, never can remember when they switched. Does the 240 have a mech speedo drive output?
        Lorin
        The M30 is God's engine.
        • phreshkid
          • 4655
          #304
          Yes, it still has the mechanical speedo drive.
          I've heard that some people prefer the g245 over the g240 because the shift forks(?) are stronger and tend to not break as much as the g240's would. But then again, I have never grenaded a transmission because of poor shifting.
          I think this is all relative. I still intend on using what this 320iS came with.
          • phreshkid
            • 4655
            #305
            I called in a towing favor from our very own Archie's Towing (Archie's Ice Cream) to transport the white 320iS from Fullerton to Long Beach, and the blue 1600 from Long Beach to Fullerton, this morning.
            If went great, zero problems, would recommend to all. Archie's is good people.
            Pictures:
            Interior is beat:
            And here is the little blue car, being loaded up on Archie's flatbed tow truck.
            Things I really want Ronin Autowerks to do:
            -Tinker with the carb, dial in the jetting and such.
            -Look at the linkage and recommend something better (for now) until I can implement a custom design.
            -Play with suspension and see what can be done to lower the front/raise the rear.
            -Move the fuel pump from the engine bay, to the trunk.
            And who knows what else they recommend.
            I mostly want them to give the car a good "once-over" to look for any mistakes or problem areas that will need addressing. I'm not a master mechanic, I'm a college student who spends too much time reading things on the internet. I make mistakes all the time.
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              #306
              Soooooo whatcha doing with that e21 steering wheel?
              That would look tasty in my e12...
              Yours truly,
              Rich
              you kids get off my lawn.....
              • phreshkid
                • 4655
                #307
                I'll get more photos tomorrow. It's yours for a small fee, if it's decent enough.
                • blue plates
                  • Feb 2014
                  • 580
                  #308
                  Get a wideband so you don't have to 'play it by ear'. Tuning carbs isn't rocket science but when you say 'it sounds like it's starving' doesn't translate to anything other than you need better diagnostic tools. It could be your timing for instance that prevents you from going WOT. Sorry if I come across hostile, people will read this and think they too can become the Carb Whisperer.
                  Originally posted by IRON-E
                  Yeah, you're definitely a vw
                  • phreshkid
                    • 4655
                    #309
                    Good advice. Ordering a wideband kit now!
                    • blue plates
                      • Feb 2014
                      • 580
                      #310
                      You'd be surprised how often you'll use it!
                      • SkiFree
                        • Jun 2011
                        • 2766
                        #311
                        Talked to Matt about some other things yesterday and your car popped up, your car is in good hands (except I'm going to swing by and snag those wheels).
                        ADAMS Autosport
                        • phreshkid
                          • 4655
                          #312
                          I hate to say this, but I'm actually thinking about selling them and sticking with 13s. 13s just seem so right for the car. And besides, the white 320iS came with the et18 Mesh wheels. Those always look good on 02s. Decisions decisions.
                          Updates:
                          Nothing on the blue car, but managed to start cleaning up the shop and check out the newly refinished Alpina wheels for the e28 m5 project. Next up on that project: Euro Bumpers.
                          Then I used one of the big fork lifts and two 2x4 pieces of wood, and lifted the 320iS off the ground. I used a big, portable steam-powered pressure washer and cleaned up the undercarriage a bit. I just wanted to get as much grease off the car as possible. This was done in preparation for the tear-down.
                          I'm looking at the wheels now and they sure would look good on the blue 1600. hmmmmmmmmmm. I need to stop having these thoughts. They are making me poor.
                          Anyways, here are photos.
                          Cut springs!
                          LSD:
                          Engine Bay; I didn't clean it.
                          Rear suspension. Bilsteins are nice, cut springs are not nice. Kooks.
                          Getrag 245! Stoked!
                          Cleanish:
                          By the time I was done, I looked like a wet dog and had grease in many of my nether-regions. I was unfit to conduct business so I wrapped it up and went home for a shower. But I did take off most of the seat covers to see what was underneath. Just as I suspected:
                          Things are moving, things are happening. I need to stay busy, I need to stay strong.
                          • CubbyChowder
                            • Mar 2012
                            • 1488
                            #313
                            Is the e28 M5 project yours as well?
                            --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
                            --Golden Boy E30 Build Thread-- (sold)
                            • phreshkid
                              • 4655
                              #314
                              Unfortunately not at this time, but hopefully in the future.
                              It's slowly becoming one of my favorite cars in the shop.
                              • DER E30
                                • Sep 2013
                                • 2349
                                #315
                                What's up with the F360 hiding back there?
                                -Christian
