Panici's '87 325is E30 - Boosted In Bronze
  • mmoyer11
    • May 2015
    • 204
    #556
    Congrats on getting out for a couple drives…it’s so reinvigorating. Car looks great…engine bay envy is real!!!
    • Panici
      • Dec 2009
      • 2482
      #557
      Thank you!
      Things were going smoothly until Sunday.
      Rinsed and foam cannoned the car off to get the majority of the dust off.
      Decided to go another 5 clicks on the manual boost controller. Car feels great and pulls hard!
      Still needs some fuel pulled up top with readings of ~10.5:1 but rather rich then lean when breaking new ground.
      I was on the highway and thought I smelt fuel. My sense of smell isn't that great, but I got off at the next exit.
      As I'm at the traffic light, guy next to me yells out "do you smell fuel?!". I said yes I think so and immediately shut off the car.
      They stopped and helped me push the car off the road.
      Popped the hood and engine bay was soaked in fuel. After I bumped the prime cycle to find where the leak was, we saw the fuel rail had been unseated from the top of Injector #5.
      Shop towels in hand I tried to soak up as much of the gas as possible. It was literally pooled at the firewall. Also had my Element fire extinguisher in case things lit up.
      Thank God I didn't have to use it. 😰
      As luck would have it, the allen wrench in the E30 tool kit was the exact size for the bolts on the Rally Road fuel rail.
      It looks like it's possible that the bolts which connect the fuel rail to the mounting blocks are too long. I had to back them out (shown in below photos) to get the fuel rail seated fully on the injectors and bolted to the intake manifold. Was able to drive the car home.
      I did change the fitting on the front end of the fuel rail earlier this year. I gave the fuel rail the wiggle test and it was rock solid both before and after, so I didn't look with a flashlight to see how it was seated on the injectors.
      It's possible that the solid feeling was from the bolts fouling on the intake runners rather then applying pressure down onto the injectors.
      The extra ~ 2lbs of boost would equate to another 2lbs of fuel pressure, but I can't see that making the difference.
      Anyways, I rinsed as much of the engine bay as I could when I got home. Paint looks okay, but who knows if the clear is damaged being soaked in gas. It certainly can't be good for it.
      The gas stripped the oils right out of the plastic intake manifold and coil cover and turned them brown/grey. Still have a little Lexol Vinylex left over after it was discontinued so I put a couple coats of that on. Will try more cleaning and conditioning with some other products to see if I can bring it back to presentable. It looks much worse in person, the photos don't show the damage well.
      Brand new fuse box cover cracked and broke the mounting tabs right off after reacting with the gas. It kept the fuel out of the fuses though.
      Need to inspect the underbody and specifically the chase bays brake line as it runs along the front swaybar to get to the passenger side. That area was likely soaked in fuel.
      All said and done I got very lucky that there wasn't an engine bay fire. And that the engine didn't lean out under boost.
      Any other damage is light compared to what fire would have caused.
      Didn't even have to get a tow truck home. Which is one flaw on the cowcatcher airdam (it blocks the factory front tow hooks)
      • mmoyer11
        • May 2015
        • 204
        #558
        Hot Damn! Glad you're ok. Great roadside job buddy. Thank god for that new fuse box lid and not having to use your fire extinguisher....going to check all my stuff before my next drive.
        • varg
          Florida Turbo Man
          • May 2014
          • 3404
          #559
          Thank goodness nothing too bad came of this. IMO, relegate that thing to backup duty and get yourself a purple K extinguisher and a passenger compartment mount for it. It would probably be ideal to break out the torque wrench and thread locker on those fuel rail bolts too. After seeing a surprise fuel leak pop up on my wagon I'm extremely anal about anything fuel system related.
          IG @turbovarg
          '91 318is, M20 turbo
          • Panici
            • Dec 2009
            • 2482
            #560
            Thanks, I was glad to not tow the car for sure.
            I know that next time if I even think I smell a hint of something wrong, I will pull over immediately.
            Originally posted by varg
            Thank goodness nothing too bad came of this. IMO, relegate that thing to backup duty and get yourself a purple K extinguisher and a passenger compartment mount for it. It would probably be ideal to put break out the torque wrench and thread locker on those fuel rail bolts too. After seeing a surprise fuel leak pop up on my wagon I'm extremely anal about anything fuel system related.
            I do have a Purple K fire extinguisher, and used to have it mounted in the trunk.
            From what I've read the Element extinguishers are superior. Is that not the case?
            Good point. I will take things apart this weekend and see if the bolts are indeed too long, and reassemble with threadlocker.
            • 2mAn
              Señior Mod
              • 20803
              #561
              Whew, dodged a bullet … all said that’s pretty minor
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              -2006 Volkswagen Jetta TDI
              Make R3V Great Again -2020
              • varg
                Florida Turbo Man
                • May 2014
                • 3404
                #562
                I looked into them when replacing some old fire extinguishers for my cars, they're marketed very heavily which made me a little suspicious. My main issue with them is that they have very short range. When activated they look like a smoke bomb, you have to get quite close to the source of the fire to use one and if there's wind it'll be competing with the fire's natural draft and require you to get even closer. IMO a car doesn't have such limited space to make the compactness particularly useful, I could see carrying one on a motorcycle, but elsewhere the size is a solution looking for a problem. The longevity they offer is maybe a little more impactful, but I'd rather check the pressure gauges on my extinguishers regularly and have something that has some range than have something that will last indefinitely but require me to get right on top of the fire to use it. A device like the Element extinguisher, automatically activated under hood, seems like it might be a decent automatic fire suppression system, but the extinguishers themselves seem more like a backup in the tool kit than something to rely on.
                IG @turbovarg
                • DEV0 E30
                  • Oct 2004
                  • 8890
                  #563
                  Wow, you most certainly got lucky.
                  Glad YOU and the car are alright dude.
                  • Panici
                    • Dec 2009
                    • 2482
                    #564
                    Absolutely.
                    And I took a look at most of the chasebays soft line going to the passenger side. All looked normal and fine.
                    Half of it was sleeved anyways with velcro on thermo protection.
                    ...the extinguishers themselves seem more like a backup in the tool kit than something to rely on.
                    Noted, I will have to mount my Purple K extinguisher again in the E30.
                    Thanks. Yes I would be emotionally destroyed if anything happened to the car.
                    I took things apart this past weekend. Reassembled with loctite and shorter bolts so they aren't hitting the intake manifold (I put a better picture in the above post).
                    Noticed the injectors were sitting at different depths into the intake manifold, which actually got worse when I bolted everything up. The deeper injectors have less engagement on the fuel rail.
                    Turns out Rallyroad makes spacers just for this scenario. https://rallyroad.net/products/injec...rev14injectors
                    Ordered on my phone and actually will be getting six SETS of spacers rather then six individual spacers. Guess I can resell the extras if they won't take them back.
                    Even though there are no leaks at the moment, I am going to wait to drive the car until I have these spacers installed.
                    And a note on the engine bay. Three different products into the intake manifold and it's looking a little better. Rear runners are still lighter/more brown. I will give it some time and more product, hopefully they even out.
                    I ordered another new fuse box cover. I couldn't find the one I took off the car, but did scavenge a rough one from my '86 325e parts which I taped in place.
                    • Panici
                      • Dec 2009
                      • 2482
                      #565
                      Injector spacers are on. They fit well as tested with a spare M50 manifold.
                      No leaks and a successful test drive today!
                      I do notice coolant temps quickly rise to 200F when stopped.
                      SPAL fan keeps things from overheating but it's riding the fan pretty well any time I stop.
                      Any suggestions for a larger aftermarket radiator with built in expansion tank?
                      Manual boost controller is also helping with spool-up.
                      At WOT in 5th gear I can build 5psi @ 2800rpm and 7psi by 3250rpm. Adds noticeable torque if you want to accelerate in a higher gear.
                      With 10 clicks on the boost controller I make 7.6 to 8 psi @4300 depending on gear and load. Tapers to 6.8psi @ 6300rpm.
                      Will probably go up some more this summer, but pretty happy with the power it makes now. Knocked the tires loose in 2nd gear once on my drive
                      I have 5 more sets (oops) if anyone needs EV14 Fuel Injector spacers for an M50B25 intake manifold.
                      • Panici
                        • Dec 2009
                        • 2482
                        #566
                        Washed the car by hand for the first time since the paint correction & PPF.
                        Looks SO glassy, I'm going to endeavor to keep it cleaner in the future!
                        Also R.I.P. 56k on this post
                        • Panici
                          • Dec 2009
                          • 2482
                          #567
