Slammin's circle jerk....it's dyno'd!!
  • slammin.e28
    שמע ישראל
    • 12054
    #421
    Hang on guys.....have to get my shaft made pls.
    Then shift linkage.
    But I've got to pull the trans one more time.....
    • 325ix
      • Aug 2009
      • 7783
      #422
      I like this thread, i'll have to keep it in mind when I start my m62 swap.
      • slammin.e28
        שמע ישראל
        • 12054
        #423
        Tawlk to me....is this self adjusting clutch really hosed if installed without the tool?
        • dirty30
          • 3014
          #424
          Was it a new clutch? If so Did you release the ninja star before you tightened the pressure plate bolts?
          • slammin.e28
            שמע ישראל
            • 12054
            #425
            Used clutch (don't judge me pls)
            • dirty30
              • 3014
              #426
              Did you use the big triangle tool thing to reset the pressure plate SAC mechanism?
              • slammin.e28
                שמע ישראל
                • 12054
                #427
                Nope, I was ignorant to this until now.
                I was going to try it on the rack and see if the thing releases when I depress the clutch, if so, I'll leave it. If not, engine comes out, trans comes off, and I reset it. Found a throwing star, friend at the dealer has one.
                • delamaize
                  • Nov 2013
                  • 1453
                  #428
                  Please god, explain this shit. I'm not far from starting my swap, and I don't wanna deal with figuring this shit out.
                  Dumpster Fire Pilot
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    #429
                    So I found a PP that works. Early e39 one. Bolts right up. No BS self adjusting....but maybe I want that adjusting PP.....
                    However, my pedal is right close to the floor for engagement. Fuk. It does release, but is low.
                    Making my exhaust.
                    Also fucking heaters hoses kicking my ass.
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      #430
                      Next post = burnout.
                      Stay tuned.
                      • stonea
                        • 2892
                        #431
                        This thread is gold
                        My Garage
                        Feedback
                        Instagram: Stone.Hopkins
                        • JGood
                          • Jan 2004
                          • 7959
                          #432
                          Do tell.
                          e30 restoration and V8 swap
                          24 Hours of Lemons e30 build
                          • slammin.e28
                            שמע ישראל
                            • 12054
                            #433
                            ***Exemption from burnout post***
                            Originally posted by JGood
                            Do tell.
                            (OMG POTATO PIC)
                            I have VAC FW, e39m5 clutch, e39 528i PP, e39 m5 TO bearing.
                            It all bolts up. 240mm clutch disc. I'm on the hunt for an OE sprung hub disc that fits the 6sp input shaft....
                            • JGood
                              • Jan 2004
                              • 7959
                              #434
                              Oh I thought you meant you found a 540i non-SAC PP. I hope the m52 PP works good for you, but I went through clutch discs pretty fast even with an aftermarket m52 PP. Just not enough clamping force for even the m60. When I went m62, I ditched it all together.
                              AFAIK, there are no OE sprung hub discs that fit. I switched over to a SPEC clutch with a sprung hub disc. They are pricey, but it's a damn good part.
                              • slammin.e28
                                שמע ישראל
                                • 12054
                                #435
                                Oh I thought you meant you found a 540i non-SAC PP. I hope the m52 PP works good for you, but I went through clutch discs pretty fast even with an aftermarket m52 PP. Just not enough clamping force.
                                Oh, interesting. We'll see how it goes. It's so easy to R&R this thing....
                                I've been super busy with moving this week....haven't touched the car since Friday afternoon. Tomorrow I may be able to work on it again. Want to redo my stupid crossover pipe. Then mount exhaust, shift linkage, and BURNOUT.
