Slammin's circle jerk....it's dyno'd!!
  • slammin.e28
    שמע ישראל
    • 12054
    #466
    • Wschnitz
      • 8089
      #467
      yeah those peaks are weird, has to be an ignition or o2 related issue id say.
      willschnitz
      • ST1G
        • Oct 2012
        • 6689
        #468
        Slammin, can you help me out with the search keywords? I can't seem to find your video.
        • stonea
          • 2892
          #469
          My Garage
          Feedback
          Instagram: Stone.Hopkins
          • delamaize
            • Nov 2013
            • 1463
            #470
            Originally posted by stonea
            This.
            No Balls. :D
            Dumpster Fire Pilot
            • slammin.e28
              שמע ישראל
              • 12054
              #471
              Have to know what gear is in before burnouts pls....
              • sticksdaman
                • Apr 2005
                • 2987
                #472
                Any pics/ details of your cooling setup? How'd you route the upper coolant hose and coolant res?
                Originally posted by ebelements
                Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
                • Good & Tight
                  • Apr 2004
                  • 2057
                  #473
                  needs turbo....
                  Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                  ____________________________
                  E-mail Panayiotisx2@gmail.com
                  Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #474
                    ^ what he said
                    1991 318i 4dr slick top
                    Mtech 2 turbo restoration
                    • digger
                      • Nov 2005
                      • 6196
                      #475
                      how many more fasts can be had from a stock m6x?
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        #476
                        I used a rad from a 524td, mostly because the upper hose inlet is at an angle into the bay, instead of pointing straight out. Tilted the oil filter over and made a bracket to hold it. The top hose goes into an inline radiator cap, then it's a couple bends I "custom" made from bits of hose I had. The reservoir is non-pressurized. This way I could put it anywhere.
                        Originally posted by Good & Tight
                        needs turbo....
                        ^ what he said
                        Eaton pls....
                        I'm thinking, with the #s I put down....300whp with just stock bolt ons (t-body, early intake, etc), cam timing adjustments, and a chip is attainable.
                        • ST1G
                          • Oct 2012
                          • 6689
                          #477
                          Is that enough to make a burnout? Now that you know what gear you're in.
                          • slammin.e28
                            שמע ישראל
                            • 12054
                            #478
                            I need to install my cooling fan pls.
                            Don't want to burn up.
                            • digger
                              • Nov 2005
                              • 6196
                              #479
                              any room for headers ?
                              • slammin.e28
                                שמע ישראל
                                • 12054
                                #480
                                Ehhh.....I don't think I'd want to try.
                                I already can't fit the right side mani in unless I lift up that side of the engine....and the left side....have to remove the lower steering column to get it in there....it's a struggle.
                                But note, those #s were put down with open downpipes.....and no o2 sensors.....a good exhaust will help get closer to my goal anyways.
