Slammin's circle jerk....it's dyno'd!!
  • lambo
    Captain Scene Points
    • 10953
    #451
    I left a small 11ses in the shop.
    No vid.
    *USELESS TEXT*
    No care.
    • slammin.e28
      שמע ישראל
      • 12054
      #452
      Originally posted by lambo
      No care.
      It's not gonna be like the vids I send you anyways, so yeah.
      • slammin.e28
        שמע ישראל
        • 12054
        #453
        Vid posted on Igram. I'm lazy.
        @therealslammin
        • 2mAn
          Señior Mod
          • 21024
          #454
          whats instagram ?
          btw I think that blue wire is the exciter wire for the alternator. check voltage while the car is running
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • slammin.e28
            שמע ישראל
            • 12054
            #455
            Was gonna goose it, but though better not.
            I need to get a elec fan on it. Core support is more fucked that I thought....need to get a replacement so I can put the front end back together.
            • Northern
              I like cupcakes & sh!tboxes
              • 5284
              #456
              @therealslammin
              D:
              I went on instagram on my laptop to see this video and no burnout.:rippedoff:
              Originally posted by priapism
              Originally posted by shameson
              • slammin.e28
                שמע ישראל
                • 12054
                #457
                Originally posted by Northern
                D:
                LOOOL
                There's dyno day the 29th in Richmond. I'm going to try to have this ready to go.
                So it probably won't be.
                • ST1G
                  • Oct 2012
                  • 6689
                  #458
                  It sounds like it could do a burn out. I think maybe the problem is between the steering wheel and the driver seat.
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    #459
                    Now I just don't wanna do one anymore.
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      #460
                      Ran the car on a dyno Saturday.
                      268hp, 276ft/lbs at the rear wheels.
                      No exhaust, no o2 sensors.
                      Fuck burnouts.
                      • JGood
                        • Jan 2004
                        • 7959
                        #461
                        Did you get a print out? Healthy peak numbers for an m60, curious to see the curves!
                        e30 restoration and V8 swap
                        24 Hours of Lemons e30 build
                        • slammin.e28
                          שמע ישראל
                          • 12054
                          #462
                          Yeah, I got the print out but forgot to get a pic.
                          I was thinking it'd be more in the 250 range. It doesn't even have the velocity stack intake mani on it. ECU is stock from a 740i.
                          The curves are....interesting. I'll remember to get the sheet tonight.
                          • JGood
                            • Jan 2004
                            • 7959
                            #463
                            Most m60's are around 250-260 from what I've seen. Most m60's also have at least 1 vacuum leak haha. I think a proper running m60 in good tune should be 260-270. Dudmd on bf.c did 266whp prior to his custom tune, then ran 276 with the tune.
                            Almost sounds like there's a flat spot shortly after starting the run, at 3500 or so?
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              #464
                              I should have remembered the sheet. It's got some odd little peaks. Thought the clutch or the wheels were slipping.....but it peaks, then keeps going up.
                              • Wschnitz
                                • 8089
                                #465
                                Probably the no o2 sensors.
                                willschnitz
