M30 OEM Turbo project
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    #286
    Thanks!
    I've got new turbo rebuild parts coming (from a more reputable source than eBay/China) which will give me more piece of mind when it all goes back together. I've already had the compressor wheel, shaft, and turbine wheel independently balanced so I don't have to worry about their orientation when it all fits together.
    I've also got the new injector wiring harness I need to attach so that I can re-install the fuel rail. Then there's some wiring and switches to wrap up, and hopefully I can get it to the exhaust shop before the end of the month!
    • CorvallisBMW
      • 13039
      #287
      It's been a while since I update this!
      I sent the rebuilt turbo out for balancing at a local shop. They balance the wheels individually, so that when it goes back together the orientation isn't as critical. It also means I can take it it apart without screwing up the balance. They did notice though that something wasn't quite right when they went to put it together, which led me down this rabbit hole:
      Long story short, I finally got all the quality pieces I needed to really rebuild this thing the right way, 100%.
      New Melett 360* thrust bearing vs the eBay 270* bearing
      New thrust washer (eBay kit didn't include this)
      The smaller, secondary kit included a new flinger ring design meant to simplify the OEM design. Unfortunately it didn't quite fit my turbo as the backing plate was too thick and caused the assembly to bind when I tightened the shaft nut. Oh well, $20 lost but no harm done.
      I didn't take any pictures of the install (it's exactly the same as what I posted earlier in the thread). Here it is back in the car!
      • ak-
        • 12422
        #288
        I like the new heatsheilds and gauge wiring. I wish mine was that clean.
        Maybe a 4-bolt to v-band downpipe adapter for your turbine?
        1991 325iS turbo
        • 2mAn
          • 20040
          #289
          Cant wait to see what this does when its all done
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          -2006 Volkswagen Jetta TDI
          Make R3V Great Again -2020
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            #290
            Gahhh cant wait to see this thing rip the streets up.
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • Alpina
              • Oct 2004
              • 838
              #291
              Really good looking.........
              one Q,, were do you guys get this GOLD insulate heat shield wrap........
              ((ala McLaren F1))
              this is quite cool,, and is it expensive ??
              Sveinbjörn Hrafnsson
              E30 CABRIO V12 M70B50 ///
              ALPINA B10 BITURBO 346 @ 507
              E34 550 V12 JML
              Finnish wisdom : If you want to Win,, hire a Finn
              http://alpina.123.is/pictures/
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                #292
                ((ala McLaren F1))
                Here you go dude.
                Free Shipping - DEI Reflect-A-GOLD Heat Barriers with qualifying orders of $109. Shop Heat Barrier and Sound Deadening Mats at Summit Racing.
                Or
                Free Shipping - DEI Reflect-A-GOLD Heat Barrier Tape with qualifying orders of $109. Shop Heat Tape at Summit Racing.
                • varg
                  • May 2014
                  • 3281
                  #293
                  Ouch, that stuff is pricy. Looks cool though.
                  IG @turbovarg
                  '91 318is, M20 turbo
                  [CoTM: 4-18]
                  '93 RX-7 FD3S
                  • CorvallisBMW
                    • 13039
                    #294
                    Yes it's a little pricey, but you only need 1 sheet for 99% of applications. I've used about 50% of mine so far, I don't know if I'll need the rest or not. Once the exhaust is done I'll have to see where some other good opportunity areas will be.
                    • Alpina
                      • Oct 2004
                      • 838
                      #295
                      Here you go dude.
                      Or
                      http://m.summitracing.com/parts/dei-010397
                      Thank you so much........
                      i LOVE all kinds of great looking vanity stuff the works
                      pretty cool i must say
                      E34 550 V12 JML
                      • efficient
                        • Feb 2012
                        • 3312
                        #296
                        Nice build
                        • gorilla
                          • 113
                          #297
                          Excellent build
                          Big Mike Hunter
                          BMW Enthusiast
                          Not2Close Motorsports
                          Like us on Facebook
                          https://www.facebook.com/pages/Not2C...35086986557277
                          • bradnic
                            • Jul 2012
                            • 3550
                            #298
                            SUB'D. phenomenal. enjoyed every post. was worried about your turbo rebuild early on - glad to see you had everything balanced and found reputable replacement bits.
                            what are you using to create the wire labels?
                            HOWTOs:
                            DB vert plastic bumpers
                            OEM Keys
                            MTech1 docs
                            88 ix Lach/Card
                            91 ic Calypso 3.1
                            86 Cosmo 2.7
                            OEM+ or bust!
                            • CorvallisBMW
                              • 13039
                              #299
                              I'm using a normal office-type label printer with 1/4" tape.
                              Managed to accomplish a few other things, like getting the oil drain hose on:
                              Also had to make some adjustments to the motor mount arm so that it would clear the compressor housing
                              But I got the turbo up pipe wrapped in fiberglass (trying to keep it cool) and installed. Plus I test-fitted the front heat shield
                              And mounted the intercooler
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                #300
                                You make fast progress. I will have to get a set of heat shields from you for my m106 mine are meh
