Bronzit E30 - OBDII S52 shaved bay - weekend/autox toy - Journey
  • Sh3rpak!ng
    • Jan 2014
    • 2667
    #1471
    Originally posted by The Dark Side of Will
    Looks like you have some tire contact inside your fender lips.
    Both front and rear are minimal. And when I say minimal I mean the fender just barely kisses the tire when doing the most aggressive driving. Front doesn't even contact enough to strip the yellow tire paint, rear is just a hair more and rubs the yellow paint so slightly. That's ideal fitment in my book - form over function right up the line.
    Originally posted by TeXJ
    I love this car and these updates <3
    thanks man
    Originally posted by jeenyus
    Love it, as always. Great work and great commitment to get this stuff done.
    thanks, as I've mentioned before I enjoy the build just as much as I enjoy driving it. So to me it's no chore to work through these projects, it's just fun. And there's no question, there's always another project.
    Shadetree30
    • Sh3rpak!ng
      • Jan 2014
      • 2667
      #1472
      Speaking of projects... cut 3 more ABS pieces to complete the ducting for the front main air entry through the lower valence and kidney grills. Now the entire radiator air flow has been ducted. I'm getting really good at CAD templates... these fit nice and snug. Tack welded a small lip to the core support to mount the lower portion and will make some small angle brackets for the ends and the side plates. There are some perfectly located and sized holes in the core support that I'll use for rivnuts and the final fasteners there. Also picked up a roll bar finally. It's a VSR1 model. Haven't decided yet if I'll run it as is or use it as a template to make my own. Either way I've got hardware incoming for mounting the seatbelts. Also picked up another nail in the damn tire. Good thing they're about ready to get replaced and sent off in a cloud of smoke. I really shredded them at the last autox. Made it out to ireland engineering open house and got some good pictures.
      Sent from my SM-G960U using Tapatalk
      Shadetree30
      • Digitalwave
        is a poseur
        • 6299
        #1473
        I'd buy some of those radiator shrouds if you could extend them down a bit. I have the stock pieces in the car but I am using "racer tape" around my oil cooler. Would basically need it to go straight down to the end of the valance and I can cut the rest from there.
        RISING EDGE
        • s14brent
          • Mar 2014
          • 570
          #1474
          i'd be down for rad shrouds as well. been meaning to do that eventually but probably won't turn out as good as my cardboard designs are still novice.
          89 325i 4dr s52
          02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
          21' Toyota Tacoma TRD OR 4x4 6 speed Manual
          • jeenyus
            • Aug 2011
            • 2064
            #1475
            Love it
            • Sh3rpak!ng
              • Jan 2014
              • 2667
              #1476
              I could probably make another set. Haven't even mounted these yet so prime time to make a master template. PM me.
              lol practive makes perfect... let's see how the first set come out for digitalwave
              Love it
              Shadetree30
              • Sh3rpak!ng
                • Jan 2014
                • 2667
                #1477
                Built some indestructible low profile ramps. Way over engineered and certainly didnt need to weld every single joint, but wanted the practice. Finally ran out of wire after I laid the last weld. I've been on this same spool since I bought the welder. Car kinda looks cool without the bumper, grills and fan. Had my favorite 4 legged fan visit for the evening. She hangs around watching and occassionally steals parts of the car to get my attention. Test fitted the cage a few more times. Had to bend the rear pads to fit the contour of the wheel well. Marked harness mount locations and roll bar mount locations so I can start drilling for installation. Sent from my SM-G960U using Tapatalk
                Shadetree30
                • wworm
                  • Dec 2016
                  • 1719
                  #1478
                  gotta love a good golden
                  ..or bronzit..
                  1984 Delphin 318i 2 door
                  • Sh3rpak!ng
                    • Jan 2014
                    • 2667
                    #1479
                    ..or bronzit..
                    seeing a theme? Though I don't usually post photos of myself, rest be assured I'm also working on maintaining this golden-bronze tan from the SoCal sun
                    Shadetree30
                    • wworm
                      • Dec 2016
                      • 1719
                      #1480
                      lmao. is your wife blonde too?
                      Alo you definitely mentioned htis earlier but is that an oil cooler or power steering cooler in the front there?
                      • Sh3rpak!ng
                        • Jan 2014
                        • 2667
                        #1481
                        As a matter of fact, yes she is, and now I'm having a good laugh
                        That's a power steering cooler. I'm not sure sure I have need for an oil cooler yet, oil temps don't seem to pass 210ish. I figure the large radiator and fan are doing a great job keeping the whole motor cool and by extension also keeping the oil cool. My water temps stay rock solid at 180* no matter what I do with the car in any condition.
                        Shadetree30
                        • rzerob
                          • Jun 2013
                          • 2315
                          #1482
                          Don't get me wrong, I really like this build but I was wondering if you had any updates on the E36?
                          • Sh3rpak!ng
                            • Jan 2014
                            • 2667
                            #1483
                            hahaha I was wondering when someone would ask again... you guys really won't let that one go will you. Aside from owing many more photos and catching up the thread to current, not much. I've been daily driving it for ~9 months now without any major issues. Had to replace a door-close sensor, need to replace the transmission bushings and replace a slow leaking coolant hose - that's about it.
                            Shadetree30
                            • rzerob
                              • Jun 2013
                              • 2315
                              #1484
                              I really enjoy reading what you come up with. I might not agree with everything but I respect the hell out of the fabrication. You could have a build thread on a vacuum cleaner and I would want to read it. But the E30 is the best in my opinion.
                              • Sh3rpak!ng
                                • Jan 2014
                                • 2667
                                #1485
                                I really appreciate that sentiment. Thank you
                                and yes I love a good vacuum cleaner too... got my parent's old miele unit they bought new in the 90s... the thing is incredible. Still a better vacuum cleaner than most new ones. I can post a build thread for it if it ever requires servicing
                                Shadetree30
