e30 325ix-86: with a Finnish touch
  • jute91
    • Nov 2011
    • 581
    #121
    Time to start giving it some love :3
    removed the front bumper, winch and the grill.
    fresh paint
    New oil to drivetrain
    Also found on Facebook - Juuso Tero, Tampere
    https://www.facebook.com/JuusosGarage
    • jute91
      • Nov 2011
      • 581
      #122
      So there is rust. lot's of it! :(
      New headlights for the ix and HJ. Those xenon high beams are for the HJ also :)
      • jeenyus
        • Aug 2011
        • 2064
        #123
        so happy you're changing the headlights! Thanks for keeping us updated on the build.
        • jute91
          • Nov 2011
          • 581
          #124
          New headlights going on
          I had to move radiator downward by the amount of the lift because engine ( which has VC fan) is bolted on the frame and radiator is bolted up to chassis
          Time to start making more clearance for the winch
          and replace the axle seal
          • litu
            • 848
            #125
            Wow, that radiator is bad....
            So nothing new at Bmw??
            https://www.facebook.com/Cry_77_IX-110483784967661
            https://www.instagram.com/cry_77_ix/
            • jute91
              • Nov 2011
              • 581
              #126
              So the wheel bearing had been replaced a while ago.. that didn't go quite well, wonder why...
              • jute91
                • Nov 2011
                • 581
                #127
                Started making clearance for the winch
                Axles are ready, except the brake calipers are stuck and they didnt get any better by moving pistons back and forth.. so I need to buy new calipers, they are cheaper than rebuilding these..
                I'm trying to solve the oil pan leak... the thread has cut on it and the sealing surface has also a edge like it's from the factory..
                • jute91
                  • Nov 2011
                  • 581
                  #128
                  • jute91
                    • Nov 2011
                    • 581
                    #129
                    Made it to work :D it's F*cking cold! -28°C in the morning. There was in the news that somewhere in the Russia was measured a -72°C this morning.. dont even wanna think about it...!
                    • Northern
                      I like cupcakes & sh!tboxes
                      • 5284
                      #130
                      holy shit that's cold. It was -12C the other day and I thought I was going to freeze to death.
                      Originally posted by priapism
                      Originally posted by shameson
                      • jute91
                        • Nov 2011
                        • 581
                        #131
                        Doch Mustang Head Gasket on m10 block
                        • petrolhead
                          • 421
                          #132
                          Interested to see if this will go somewhere. I've seen the idea being tossed around the internet. That setup would need custom cams and custom timing gear. I'm betting that that Ford v8 isn't cross plane crank but a 90 degree thing?
                          I'm just guessing, but by the time that engine would be ready to run, you'd have spent enough for an S14 head.
                          That said, the same money would build a very big displacement M10 with a very special head :)
                          • jute91
                            • Nov 2011
                            • 581
                            #133
                            That's Motorsport ;)
                            My motto is: Do things little different than others.
                            S14 heads are rare and putting s14 head on m10 block has been done dozens of times. I just want to use my imagination. M10 block = thick walls, great for boost. M10 head = not that great head.
                            • petrolhead
                              • 421
                              #134
                              No it probably won't flow 300 hps worth of air, but bear in mind what it is: A very simple, reliable lightweight SOHC head. Compared to others in that category, it's not half bad.
                              But like I said, I'll be interested to see if this becomes something.
                              "S14 parts rare".. you can still buy S14 parts from the dealership. Not even that expensive when you compare it to a used parts that you'll be having machined etc.
                              By the way, I can totally dig your idea of a 4 cylinder iX. I believe you are or were considering something in that order?
                              -Jarno
                              • jute91
                                • Nov 2011
                                • 581
                                #135
                                but still the main point with the s14 is that it has been done..
                                I like to discover new things. Just like in the mechanic movie.
                                Mechanics, we are problem solvers
