e30 325ix-86: with a Finnish touch
  • jute91
    • Nov 2011
    • 581
    #106
    Originally posted by petrolhead
    Digger: whether a pedal box setup is road legal or not in Finland, is open to debate.
    Much of the stuff we build just has to look OEMish so the MOT inspector wont notice your custom parts.
    Pedal box is legal with the certificate from the producer.
    Also found on Facebook - Juuso Tero, Tampere
    https://www.facebook.com/JuusosGarage
    • jute91
      • Nov 2011
      • 581
      #107
      Originally posted by digger
      i think he meant since youre so open to hacking and customising , why not ditch the booster and run a pedal box setup. also you can build a proper setup with stock booster. some even shift the stock booster over an inch or so which would make it 10x easier to make a plenum. also smaller booster and corresponding caliper and m/c changes along with the offset position and would help again
      I ran over couple ideas, had bought several boosters for the mockup but decided to run this setup. It gave me lot of room. ;)
      • jute91
        • Nov 2011
        • 581
        #108
        new ignition coils
        heater pipes are going to need some modifications too
        • jute91
          • Nov 2011
          • 581
          #109
          Took some practices to the students at school ;)
          Now when I have centering hub for the flywheel, it's time to
          put it on a diet.
          • squidmaster
            • Aug 2011
            • 2666
            #110
            Love everything! Craftsmanship and creativity like this is very respectable. Thank you for sharing with us :)
            • Kershaw
              • 11822
              #111
              such an awesome build.
              AWD > RWD
              • jute91
                • Nov 2011
                • 581
                #112
                just ordered one of these ;) I want to hear the straight pipe, but not all the time ;) plan is to take 2x2,5" pipe from front to the back, 2-to-1 joint after collectors and then cut out shares it back to 2x2,5" which will lead to the back of the car, one silenced, one straight.
                Prepping flywheel to be machined.
                • Alpina
                  • Oct 2004
                  • 838
                  #113
                  I must say,,, VERY WELL DONE,,, so far
                  Sveinbjörn Hrafnsson
                  E30 CABRIO V12 M70B50 ///
                  ALPINA B10 BITURBO 346 @ 507
                  E34 550 V12 JML
                  Finnish wisdom : If you want to Win,, hire a Finn
                  http://alpina.123.is/pictures/
                  • jute91
                    • Nov 2011
                    • 581
                    #114
                    • jute91
                      • Nov 2011
                      • 581
                      #115
                      electrical cutout system arrived from the US :)
                      And facelift CPS combo came from the UK
                      • jute91
                        • Nov 2011
                        • 581
                        #116
                        Taking final measurements from the crankshafts
                        So the m20 crank bolt bottoms in m57 crank. Problem is that m57 has longer threads in the crankshaft.
                        Bought m57 flywheel bolts for automatic transmission. Same size, only longer threads.
                        And it fits!
                        • digger
                          • Nov 2005
                          • 6206
                          #117
                          Don't forget the gall plate adds a another couple mm so you have more margin
                          https://www.ecstuning.com/ES20337/
                          • jute91
                            • Nov 2011
                            • 581
                            #118
                            almost forgot :D
                            • jute91
                              • Nov 2011
                              • 581
                              #119
                              Sold my volvo and bought toyota hj60 from Lapland! :)
                              back in home
                              HJ needs some repair before it can be thrustworthy daily :)
                              Starter motor gave up so I had to took it apart and fix it.
                              new bearings and bendix unit
                              Took the front output shaft out because it started making a noise also
                              Little wear so I'm going to use it only in L4.
                              Greased it well and installed back in the car.
                              • Northern
                                I like cupcakes & sh!tboxes
                                • 5284
                                #120
                                I like the progress!
                                Originally posted by priapism
                                Originally posted by shameson
