e30 325ix-86: with a Finnish touch
  • litu
    • 847
    #76
    That sound awesome :)
    https://www.facebook.com/Cry_77_IX-110483784967661
    https://www.instagram.com/cry_77_ix/
    • jute91
      • Nov 2011
      • 581
      #77
      Had to smoothen some edges from rods to make out more clearance to the block. found out that one of the connecting rods were cracked...
      So I need to find another set now.. bought already another m20b25 set but it's different, newer mold.. Now I'm seraching for m54b30 rods, they are over 100grams lighter than these and I'm sure they can handle the power
      Also found on Facebook - Juuso Tero, Tampere
      https://www.facebook.com/JuusosGarage
      • jute91
        • Nov 2011
        • 581
        #78
        replaced the 1 speed fan with the 3 speed fan found out from my e39
        • litu
          • 847
          #79
          Cool, i was wonder how this project is comming
          • Northern
            I like cupcakes & sh!tboxes
            • 5281
            #80
            The electric fan was a good move.
            Originally posted by priapism
            Originally posted by shameson
            • jute91
              • Nov 2011
              • 581
              #81
              • litu
                • 847
                #82
                cool
                • petrolhead
                  • 421
                  #83
                  Originally posted by digger
                  also a slight curve on the runners doesnt hurt anything at all should you not want to use a smaller booster, clio booster is very common in the UK
                  A VW Golf (mk II 1,3 CL) has an even smaller booster. Bolts right up, the lever that attaches to pedal just needs to be shortened. Renault, BMW, VW, doesn't matter, they're all made by ATE.
                  Originally posted by Wschnitz
                  Still its a lot more work for the same power, The S54 block at least bolts up.
                  S54 seems to be the right answer to just about anything around here. Nevermind the cost to get one and have it in really proper condition, weight, etc.
                  Juuso, keep it up! Following this with great interest.
                  -Jarno
                  • jute91
                    • Nov 2011
                    • 581
                    #84
                    making the mold for the intake ports
                    Fixed the valve spring test bench and took some measurements from stock springs.
                    Metric mechanic uses almost same stiffness but lighter package
                    • jute91
                      • Nov 2011
                      • 581
                      #85
                      brake booster setup arrived, guess I need to give it a little touch to make it fit, as usual :)
                      • jute91
                        • Nov 2011
                        • 581
                        #86
                        Brake setup might be next on. Brake mechanism from bmw 540i, brake booster from suzuki swift and master cylinder from volvo 240.
                        • stonea
                          • 2892
                          #87
                          Any particular reason you went with the swift booster and 240 master cylinder over OEM BMW?
                          Sent from my SM-G920V using Tapatalk
                          My Garage
                          Feedback
                          Instagram: Stone.Hopkins
                          • 6A LDY
                            • Jul 2014
                            • 318
                            #88
                            Sub'd this is awesome.
                            Do you have any numbers on the pressure in the brake lines from the stock m20 booster vs the suzuki swift booster? I'd be interested to see if they put up comparable numbers in all 4 lines under braking. If so this could be an interesting option for swaps that people want to keep the booster and add a BBK but not lose stopping power
                            1988 325iX - sold but not forgotten
                            1984 MTech1 323i
                            • jute91
                              • Nov 2011
                              • 581
                              #89
                              Sizing. Swift booster was the smallest one that I found from the graveyard.
                              And BMW master cylinder didnt fit into it and I tried volvo one and it was perfect!
                              I didnt want to move the ABS unit and this setup helped me through it.
                              Also the brakes will need a bit more footwork now while the booster got smaller and master cylinder went up from 20mm to 22mm. Curious to see how it works :P
                              • TrentW
                                • 2815
                                #90
                                I like your ethos and skills sir.
