Let's make an E30 M3! (M3 S14 cabrio clone project)
  • IronJoe
    • 2275
    #226
    Finally carved out some time to tear into the motor. I removed the head and found two exhaust valves of #4 bent (as expected). I took out the old valves, lapped & installed new ones along with new valve seals. Cleaned everything up and started putting it back together.
    As per usual, there were a few gaskets, hoses, and seals that I thought I'd better replace so once again I am awaiting shipments to finish her up..
    If you look carefully here, you can see the valve stems from the opening! There's my 0 psi compression!
    Bent valve, meet new valve.
    New valves lapped & installed.
    Head & cam box back on!
    '89 Schwarz E30 M3 Cabriolet Build
    • flyboyx
      • 8371
      #227
      happy to see an update.
      Gigitty Gigitty!!!!
      • QuiqueUy
        • Jul 2014
        • 127
        #228
        you had a bad patch but its coming back together ! nice update !
        • IronJoe
          • 2275
          #229
          No new photos but I got the cams installed and timing dialed in, and lots of other parts reinstalled.
          I'm now just awaiting a shipment of a new idle valve hose and I can fire her up!
          • pandaboo911
            • 2070
            #230
            If you plan to sell those startecs lemme know. Been looking for a decent set.
            Otherwise, nice build!
            • IronJoe
              • 2275
              #231
              Top end is all put back together, just about ready to fire it up once again!
              • flyboyx
                • 8371
                #232
                Gigitty Gigitty!!!!
                • M-technik-3
                  • 18946
                  #233
                  Originally posted by flyboyx
                  Sweet glad to see forward progress.
                  • WestCoastEta
                    • May 2015
                    • 475
                    #234
                    • delamaize
                      • Nov 2013
                      • 1463
                      #235
                      :popcorn:
                      Dumpster Fire Pilot
                      • spiDmang
                        • 3941
                        #236
                        fully erect.
                        you better send me a video of first start-up in the new body, with you naked in the background.
                        Cheuk HNNGGGGGGGGGG
                        91' 318iS - S54/6MT Swapped
                        08' E90 M3 6MT - Daily
                        Originally posted by IronJoe
                        Originally posted by 2mAn
                        • delamaize
                          • Nov 2013
                          • 1463
                          #237
                          Originally posted by spiDmang
                          fully erect.
                          Cheuk HNNGGGGGGGGGG
                          +1, except post'em video here.
                          Dumpster Fire Pilot
                          • IronJoe
                            • 2275
                            #238
                            IT RUNS!
                            Seriously I've waited so long for this day. The last day I got to rev this motor was October 8th, 2015. Fired her up just like old times. Actually, better than that - I think I had a small vac leak at idle that seems to have disappeared now that I have replaced all the hoses under the intake. It purrs like a dream, should be able to take her out for her first drive tomorrow!
                            Here's a quick video I took of the exhaust. More to come tomorrow :D
                            • Shock(/\)ave
                              • 350
                              #239
                              IT RUNS!
                              • delamaize
                                • Nov 2013
                                • 1463
                                #240
                                IT RUNS!
                                Dumpster Fire Pilot
