Let's make an E30 M3! (M3 S14 cabrio clone project)
  • rzerob
    • Jun 2013
    • 2315
    #256
    Great job so far. What color do you plan on painting it when you are done?
    • Shock(/\)ave
      • 350
      #257
      Pepto pink I think. ;D
      • IronJoe
        • 2275
        #258
        Currently chasing down electrical issues after the swap. For some reason, the car is hard to start (it cranks for a while before it starts popping and firing) so I believe it must be a fuel issue. Maybe the fuel pump isn't turning on right away... If it's been running a while, and I turn it off and on again it fires right up. So fuel? Cold-start settings? Other? I'd love your thoughts, r3v.
        Also the tach is intermittent, the brake check light is on, and there are several other little issues to track down. Once she's ready for some real driving I'm going to start disassembling the rear end (interior, trunk, etc) for the bodywork portion of the project.
        Here's a picture I liked.
        '89 Schwarz E30 M3 Cabriolet Build
        • UNHCLL
          • 8790
          #259
          Fuel is draining back in the lines, and requiring you to re-build pressure in the rail before it will fire/run on 4 cyls. Install a pressure gauge in-line if you want to verify.
          Also, what was your shim thickness for the 2 new exhaust valves vs. the rest of your shims?
          Below the radar...
          • IronJoe
            • 2275
            #260
            So I think I've fixed my slow starting problem by filling the car with fresh gas. Also I'm replacing the fuel filter and all the lines just in case. I've got a few little issues to work out but it's running well enough to drive to get the bodywork done.
            Just for fun, I was playing around with the vinyl cutter and made this. Not sure if I'll keep it but it was kind of a cool idea someone suggested. "Spirit of Henna Red"
            More (big) updates coming soon!
            • delamaize
              • Nov 2013
              • 1452
              #261
              Keep the Decal man, It's awesome, and a fitting tribute.
              Dumpster Fire Pilot
              • IronJoe
                • 2275
                #262
                Small update, got a few minor things done to get her more roadworthy. I changed the fuel filter, adjusted the driver door window, and most importantly, got the brake lights working. I also put the hood on, for its first real adventure is today. I have much more of this little stuff to tackle. Turn signals don't work, tach is intermittent, gas gauge is inop, etc.
                Another issue was that the wheel/tire and spring setup was far too aggressive for non-M3 rear wheel wells. I ended up adding 1" spring spacers to raise the rear until the M3 bodywork is completed.
                4x4 rear end :p
                • IronJoe
                  • 2275
                  #263
                  Man, I love this forum.
                  I was really stumped at why my turn signals weren't working, I knew I had them working before I tore the car apart. The turn signal stalk created a strange "buzzing" noise whenever I engaged it - then I found this thread:
                  Apparently when I did the dash install, I had swapped the four-way flasher switch with the rear window defrost switch. Totally spelled out in that thread from almost ten years ago! Such an easy fix as I was ready to tear into the wiring which would have been all for nothing.
                  Nothing new other than I've put some more miles on the car. Drove it to my friend's shop while it was snowing, boy that was weird.
                  • Den_k321
                    • 1248
                    #264
                    cant wait to see it in person!
                    1988 325is S50 in-progress.
                    http://www.facebook.com/E30LocalCrew
                    Few pictures:
                    http://www.r3vlimited.com/board/showthread.php?t=255061
                    • IronJoe
                      • 2275
                      #265
                      Thanks Dennis! Hope you and the family are doing well :)
                      Small update, I met with the body shop yesterday and we started planning out the work. Since this is the most crucial aspect of the build, I am taking my time with specific measurements, etc.
                      I've started measuring and marking up the new quarter panels and the current panel on the body. I'm pretty excited!
                      • flyboyx
                        • 8371
                        #266
                        Man, I can't wait to read through all of your documentation on this aspect. Do you somehow have the bottom portion of your front fenders mounted?
                        Gigitty Gigitty!!!!
                        • IronJoe
                          • 2275
                          #267
                          Yep!
                          • flyboyx
                            • 8371
                            #268
                            que paso?
                            Gigitty Gigitty!!!!
                            • bradnic
                              • Jul 2012
                              • 3552
                              #269
                              Updates please!! Such an inspirational project
                              HOWTOs:
                              DB vert plastic bumpers
                              OEM Keys
                              MTech1 docs
                              88 ix Lach/Card
                              91 ic Calypso 3.1
                              86 Cosmo 2.7
                              OEM+ or bust!
                              • IronJoe
                                • 2275
                                #270
                                Yes, I am still here. No, it isn't done yet
                                Small updates. I got my Sport Evo sill covers in from Germany, what a delicious waste of money.
                                I think I finally have the resources in place now to complete the rear bodywork - I have a shop lined up to do the work. I am still waiting on OEM inner wheel arches - I refuse to do this project any other way.
