Let's make an E30 M3! (M3 S14 cabrio clone project)
  • Wschnitz
    • 8089
    #211
    At least it didnt grenade the cylinder!
    willschnitz
    • dude8383
      • Jan 2005
      • 10387
      #212
      Perform a leak down test.
      • flyboyx
        • 8371
        #213
        aw damn. it does indeed sound like a valve issue. i guess it doesn't mean that you bent a valve, but its possible. you might simply have a clearance issue. you my try loosening the cam journals to relieve the pressure off your valves, then do another compression test to see if that helps.
        its also possible that during assembly, some microscopic part fell down the intake and is wedged in between the valve and the head. its also possible that one of the spacers between the cam and the valve is stuck.
        if you do pull the cams back off, run the number 4 cylinder to bdc and tap on the top of the valves with a mallet. you should be able to feel if one is stuck.
        Gigitty Gigitty!!!!
        • IronJoe
          • 2275
          #214
          Update: I ended up checking the valve lash, and found the culprit.
          Exhaust valves on #4 had 5x the lash as the rest of them - obviously they aren't closing fully. I suspect they are bent, so I ordered new ones and will be pulling the head off shortly to replace them. I have the OEM headgasket and other associated gaskets on order.
          It's a bummer, but in the long run I'll be happy I have a new headgasket on the S14 as I've run her for 6+ years and have no idea when it was last done.
          '89 Schwarz E30 M3 Cabriolet Build
          • IronJoe
            • 2275
            #215
            It's really a bad sign when your head gasket kit arrives like this:
            The perfect curvature for a head gasket -_-
            More waiting. :(
            • AWDBOB
              hooptie connoisseur
              • Aug 2013
              • 4516
              #216
              What HG Kit did you get?
              • 2mAn
                Señior Mod
                • 21093
                #217
                Its hard to be at your house and NOT a little erect
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • igor700
                  • 21
                  #218
                  Love this build. Keep at it.
                  • Kershaw
                    • 11822
                    #219
                    Lol, it looks like it was run over.
                    AWD > RWD
                    • bobaflesh
                      • Mar 2016
                      • 69
                      #220
                      Oh crap, not good on that HG.
                      • IronJoe
                        • 2275
                        #221
                        Goetze. According to a few folks on S14 it's a reasonable replacement for the Genuine BMW gasket which has been on national backorder. No way in hell I was going to put a Victor Reinz hg on this car.
                        Good point. Probably shouldn't blame UPS for this one ;)
                        • kid325e
                          • Sep 2007
                          • 6422
                          #222
                          How anybody packages a gasket like that then assumes it will arrive without any damage is beyond me. That sucks!!
                          clutchCTRL!
                          Move with a purpose.
                          - 1991 325iX 4dr/5spd
                          - 2000 323i AT
                          2016 Mazda CX3 Sport AWD
                          • Fucatypr
                            • Dec 2016
                            • 108
                            #223
                            Sucks about the headgasket. I can't wait to see the car finished.
                            1993 BMW 850ci factory 6 speed
                            1992 Honda Civic Hatch, built B16, turbo, and nitrous
                            1989 BMW 325i, f20c swap
                            1989 Honda CRX, built LS/vtec, turbo, and nitrous
                            • AWDBOB
                              hooptie connoisseur
                              • Aug 2013
                              • 4516
                              #224
                              Awesome, thanks! I've been dealing with that same internal battle with the Goetze sitting in my 'cart,' knowing there is no way I'd put a VR on the car.
                              • Eric
                                • 5142
                                #225
                                Originally posted by UNHCLL
                                Your dealer is doing something "right" to be able to make that work - but I suspect they'll get their hands slapped by corporate at some point. Take advantage while you can, and don't publicize their name. ;)
                                This exact thing happened to my dealer! I was ordering euro parts long after I saw people being denied on here from other areas of the country, then one day my dealer was shut off too :(
