Project Weißer Regen: 91 318iS Restomod
  • getouth
    • Jan 2010
    • 3343
    #796
    This thread gets cooler with every post!
    Drive Tastefully!
    FEEDBACK:
    http://www.r3vlimited.com/board/showthread.php?t=316212
    BMWCCA #398608
    IG @yagayo38
    "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
    • bmoores
      • 151
      #797
      Drive Tastefully!
      Agreed. Can't wait to put eyes on this thing when its officially done.
      17 Range Rover Sport SVR
      14 Q5 TDI S-Line
      ...on the hunt for another E30.
      • zaq123
        • Jul 2016
        • 1573
        #798
        Very neat. Didn’t know such a tool existed. You said the tool makes a double flare? Looks like a single...maybe just a pic
        • Jordan
          • 12916
          #799
          He made the tool, and also made the new rivets from stainless steel. He preflares one end of the rivet with a different tool so once it is loaded into the hand held tool you only fllare the interior side.
          https://mtechniqueabs.com/
          • AndrewBird
            The Mad Scientist
            • 11898
            #800
            Not a double flare like a brake line, he just means 2 flares, one at each end.
            • Jordan
              • 12916
              #801
              Made a bit of progress yesterday although I feel like I should have been able to make more... Today will hopefully be more productive.
              Yesterdays main task was cleaning, sanding and repainting the window lining trim. For this SEM 49133 Trim Black Ultra Matte was used. The legacy paint I've always used (SEM 39143) is charchol in color by comparison. A note made that the ultra black line is more glossy than the legacy line so stepping down to Matte is a perfect sheen, where as the ultra black Satin is too much.
              First off the bpillar covers required extensive sanding as they were covered in small scratches, presumably from rings or something. They would be first to get many coat, wet sanded down smooth, and then a top coat along with the small trim joiners.
              The forward/upper window frame trim would be next.
              and we'll get the dried trim on the car before I trip over it.
              Rain gutter trim next up
              While those are drying I'll attach the lower window molding, which was already painted earlier I just didn't picture.
              With new door dew wiper and mirror assembly
              New clips for the roof gutter modling
              and installed
              Lastly I put the first piece of glass into the car some time later. All of the glass is going to get a once over with cerium oxide prior to install so it looks as nice and slick as possible. The polish did a really good job with the vertical scratches from aged window seals completely removing all but a few. I can live with what is left, in trade I get a set of period correct glass with the correct production stamps and DOT numbers for the car. New glass from BMW the bug stamps are all weird and totally different than original.
              After that I moved onto the dashboard, blew all the duct work apart and loaded up the dishwasher came out very nice and clean with next to zero effort on my part.
              Letting dressing soak into the dash a bit before buffing it to a dry satin shine.
              • 2mAn
                Señior Mod
                • 21088
                #802
                What’s a good way to clean and protect the dash?
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • Jordan
                  • 12916
                  #803
                  I like 303 aerospace protectant myself. It brings out the color, and dries to a satin/matte sheen. Doesn't attract dust or get slimy.
                  The dashboard pictured is actually headed for the trash though, it has a repaired area I just don't like and I can't use it.
                  • 2mAn
                    Señior Mod
                    • 21088
                    #804
                    Why not let someone else use that “trash”
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • Jordan
                      • 12916
                      #805
                      I mean, if someone in Houston wants it... sure. Trash day is Tuesday though and I don't have space or patience to have it laying about. Sad thing is that it was perfect but FedEX fucked it up, they don't appear to want to pay the insurance claim, so I had a local specialist attempt a repair which came out lousy, so now I'm doubled down into this turd.... I just want it to go away. $600 wasted.
                      This mornings project was painting the lower skirting black as was factory. Masked it all off and took to it with red scotchbrite to give the paint a solid key into the clearcoat.
                      Then spent awhile masking everything off.
                      Ah nice nice.
                      Hovercar is hovering
                      • Javier h
                        • Sep 2007
                        • 1189
                        #806
                        I saw on ebay remanufactured dashes....not sure exactly what that means...but color appears off. Has anyone tried one?
                        https://www.ebay.com/itm/BMW-E30-Bla...wAAOSwjXZcfBTH
                        I just hope its not just some crack filler!
                        • Melon
                          • Mar 2018
                          • 1311
                          #807
                          Bummer man, I understand the frustration.
                          Don't let it go so soon, you can surely recoup some cash.
                          Trim is looking good man!
                          I do things.
                          • TeXJ
                            • 1914
                            #808
                            :slowclap:
                            1990 325is
                            m52b28
                            3.73lsd
                            g260 (1987 325is 5spd tranny)
                            • 2mAn
                              Señior Mod
                              • 21088
                              #809
                              Originally posted by Jordan
                              I mean, if someone in Houston wants it... sure. Trash day is Tuesday though and I don't have space or patience to have it laying about.....
                              Someone better get out there! Too many terrible dashes on cars right now to let a less than perfect one get dumped...
                              I love the OEM goodness that the black textured lower line provides. Used to be the other way that I loved it color matched.
                              Excited to see the hovercar land :p
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              • flyboyx
                                • 8371
                                #810
                                put that dash aside for me Jordan. i will come and get it this week.
                                Gigitty Gigitty!!!!
