Project Weißer Regen: 91 318iS Restomod
  • zaq123
    • Jul 2016
    • 1538
    #811
    why the tank/subframe is out again? It was all fitted and clamped so nicely in there, what happened?
    • Jordan
      • 12916
      #812
      Originally posted by flyboyx
      put that dash aside for me Jordan. i will come and get it this week.
      The guy that "fixed" the blemmish wants to have another go at it, if it comes out lack luster again you're welcome to it friend.
      Because bodyshop dust and grime. Had to blow it all apart to clean it adequately.... Will be going back on this week.
      New toolkit foam and toolkit tray, no tools worthy of the car yet!
      Rear Euro plate filler, and my old Texas E30 plate (now owned lawfully by my friend Thad) but I still have my old one as a place filler :-)
      Positive battery junction installed along with the blower housing/cowl cover
      Rear brake splitter, new soft lines and custom bent hard lines. I just had to change out the flare nuts for freshly plated ones which means remaking the flares which means making new lines. The factory no longer supplies prebent lines so I artfully recreated these in original shape. What a pain in the ass!
      Rear brake proportioning / limiting valve.
      Got the door locks installed with the mounting fixtures and all that jazz, wanna talk about a pain in the dick to assemble....
      As people asked earlier here is a preview of my plug and play US sealed beam to Euro adapters.
      and last little morsel for the evening, new Pukar Designs reproduction door jamb stickers.
      https://mtechniqueabs.com/
      • iXguido
        • Nov 2009
        • 729
        #813
        Is the toolkit tray support black on the new toolkits? I’ve only seen them in gray before.
        • e30RS
          • Mar 2019
          • 437
          #814
          This is a superb looking base. Good luck with the build.
          • Digitalwave
            is a poseur
            • 6299
            #815
            Why adapters for the headlights instead of rewiring them proper?
            RISING EDGE
            • mbonder
              • 2255
              #816
              Originality would be my guess. That way you can always return the car to 100% original by putting sealed beams back in.
              • jeenyus
                • Aug 2011
                • 2064
                #817
                where did you acquire the rear euro plate filler in that good of condition?
                • zaq123
                  • Jul 2016
                  • 1538
                  #818
                  I believe they are still available brand new.
                  • Jordan
                    • 12916
                    #819
                    Because I don't want to cut the harness. This way it remains completely modular and could be easily reversed should someone want to down the line.
                    It is a old and well used panel, it was refreshed with SEM trim black paint the same as used everywhere else. I bought it from Levent @ Guten Parts.
                    • Staszek
                      • 2533
                      #820
                      Those are awesome. I need to get those!
                      • econti
                        • May 2014
                        • 1147
                        #821
                        I never knew that LHD scuttle panel covers (the plastic bits where the wipers are) are different to RHD. Something new every day
                        • Melon
                          • Mar 2018
                          • 1311
                          #822
                          Question:
                          I lined up my door strikers so that the door sits flush with the body, but it takes a little gusto to close it. Is this normal with new door seals, or should I go back and readjust the striker?
                          I do things.
                          • Jordan
                            • 12916
                            #823
                            Originally posted by Melon
                            Question:
                            As did I and initially the doors were a serious pain in the ass to close. After having been latched closed for almost two weeks the closing effort is nearly normal. The seals should relax a bit more over time and become completely normal. The imola car was the same way with its new seals.
                            • Melon
                              • Mar 2018
                              • 1311
                              #824
                              Cool man, that's what I figured.
                              Thanks.
                              I do things.
                              • CaptRiskyBiscuits
                                • Mar 2019
                                • 6
                                #825
                                I just finished reading through the red e30 build and this one and I'm absolutely amazed at the attention to detail! So excited to see this car finished! But I'm also sad I don't have more to look through. I also learned a ton! So thank you for taking all the time to show all the work your doing!
