Project Weißer Regen: 91 318iS Restomod
  • roznic
    • Mar 2013
    • 2876
    #826
    Simply beautiful...
    Is that PS reservoir bracket/holder OEM m42 or required some mods on your end??
    • Jordan
      • 12913
      #827
      Originally posted by CaptRiskyBiscuits
      I just finished reading through the red e30 build and this one and I'm absolutely amazed at the attention to detail! So excited to see this car finished! But I'm also sad I don't have more to look through. I also learned a ton! So thank you for taking all the time to show all the work your doing!
      I try to post updates as often as possible :-)
      Originally posted by roznic
      Simply beautiful...
      PS reservoir and bracket are original M42 spec parts.
      Got the fuel tank, rear subframe and trailing arms reinstalled last night.
      https://mtechniqueabs.com/
      • AndrewBird
        The Mad Scientist
        • 11898
        #828
        Invisible trailing arm mod. Nice!
        • econti
          • May 2014
          • 1143
          #829
          it's the lightweight model
          • plmichal
            • 718
            #830
            A real inspiration to not cut costs on my own restoration.
            What are you using between the jack stands and front frame rail? Are those two stacked tires under the spare wheel well supporting the rear end while the subframe/diff/accessories are out? Thanks.
            1990 325is Brilliantrot/Natur
            • Jordan
              • 12913
              #831
              I love inspiring others to take it up a notch, even if not full retard like me, something is always more :-)
              I have new hockey pucks between the jack stands and the front frame rails. They are wide and non marring. We buy them by the case at work to use on each lift arm to space the arms down off rocker skirts and such.
              Yes, 100% two of the cars wheel and tires lol, with moving blankets padding the tires top and bottom. I was moderately concerned the spare tire tub might be dented but the car is now back on all fours and the tub is fine you can't even tell.
              With the rear suspension out and freshly refinished pinch welds I couldn't really work out a better place to support the ass end and this worked well.
              For the smart asses here are the trailing arms now installed, along with hubs, rotors, calipers etc.
              The only hard brake line that will be reused on the car is the mega long run from the proportioning valve under the master cylinder back to the T under the rear seat. It was in great shape but all of the other lines have scratches, dings and mild corrosion that is simply not acceptable. I will remake each line by hand from new bulk tubing which also allows to be slip on freshly plated flare nuts.
              Rear brake line that mounts to the trailing arm, new one has the nuts in place.
              Hovercar, now with its suspension in place.
              Front suspension, with rotor and caliper in place.
              Underside of the front suspension
              Transmission tunnel
              Rear differential hoisted up into place and bolted in. Getting the four bolts that support this thing started I swear are the worst shit to do on these cars. Been there done that more times than I can count and its always the same shit
              Hey a driveshaft!
              Shoved the shifter up into its home while I was under here, supporting the front of the shifter and driveshaft with zipties through the rear evaporator drain for the time being. Another Pukar sticker on the driveshaft.
              With heatshields and chassis brace in place.
              Lastly I closed out today breaking down the second shelf to take back to work as I'm now able to consolidate the remaining parts onto just the one shelf.
              • parkerbink
                • Jun 2004
                • 10138
                #832
                Just amazing. If BMW made them like this a '90 318 would have been 100k.
                lol
                • Melon
                  • Mar 2018
                  • 1311
                  #833
                  Looking great man, and after the paint delays I'll bet you're enjoying every minute of it. I hope you're having in Houston like we're having in BR, it's been gorgeous.
                  I do things.
                  • econti
                    • May 2014
                    • 1143
                    #834
                    RE the diff - I made studs to be fixed in the diff permanently, which made it 999x easier. No it's not factory but I couldn't care less
                    • rzerob
                      • Jun 2013
                      • 2315
                      #835
                      I agree. And don't sell yourself short. If I was you, I would list this for sale as 100k obo. It is a better than factory, no corners cut detailed documentation full concourse rebuild. This is probably the best factory rebuild of an E30 ever. And people will pay good money for just that.
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        #836
                        :nice:
                        • fresh_TD
                          • Aug 2013
                          • 2457
                          #837
                          Just to put it in perspective. $100k is e30M3 Evo money. I don't care if it's the cleanest restored 318is in the world. They will never fetch e30M3 Evo money. C'mon man
                          Sent from my Pixel 3 using Tapatalk
                          '91 318i (Alpine) - daily
                          '88 325ix (Zinno) - drive here and there!
                          • flyboyx
                            • 8371
                            #838
                            no offense, but you are so wrong about this. now much would that evo3 be worth done to this level? there is a guy in vegas that does nut and bolt restorations on 2002's for about 125k a pop. he has more work than he knows what to do with. there is a market. it is small, but it is there. Jon is no dummy.
                            aaaannd.....keep up the good work jordan.
                            Gigitty Gigitty!!!!
                            • fresh_TD
                              • Aug 2013
                              • 2457
                              #839
                              When this sells for $100k, I'll buy you a case of beer of your choice. I'm pretty sure I'll never end up having to buy you a case beer.
                              • rturbo 930
                                • Dec 2005
                                • 2621
                                #840
                                I could see $50k to the right person. $100k? No chance. And 2002s are much rarer, and arguably more desirable than an E30.
