Melon's E30 Build.
    • 34844
    #316
    When replacing the selector shaft seal - don't remove the old one. Just put the new one right over top of the original.
    • zaq123
      • Jul 2016
      • 1560
      #317
      that only works if there is only one in there :)
      • Melon
        • Mar 2018
        • 1311
        #318
        I only had one, but wanted to clean and inspect the sides of the sealing surface, so out it came, and what a fucking bitch to get out.
        I do things.
        • Melon
          • Mar 2018
          • 1311
          #319
          Booster gasket installed, used some foam I had.
          So, I thought I didn't install the gasket between the master cylinder and the brake booster, turns out I did and it slipped inside the booster somehow, so glad I decided to do this.
          It's a bit folly, the grommet for the clutch master cylinder line can leak.
          I'll wait and see.
          I do things.
          • Melon
            • Mar 2018
            • 1311
            #320
            Painted the rear calipers.
            Re did the vacuum lines to the charcoal canister.
            Sent from my Pixel 2 using Tapatalk
            I do things.
            • Melon
              • Mar 2018
              • 1311
              #321
              Hood on!
              I do things.
              • majdomo
                • Jun 2018
                • 449
                #322
                Sweet!!! When do you plan to take out for a spin??
                Current flame: E30 318iS Alpinweiss II slicktop / LSD - Joanne
                The old man: 1970 2002 Polaris(ish) slicktop / rat rod - Wallace
                The ex: E92 335i 6MT M-Sport - Betty
                The heavy: 2001 4Runner SR5 Sport (3rd Gen) - Fred
                • Albie325
                  • Jul 2016
                  • 515
                  #323
                  What rotors are those? Look pretty sweet
                  '86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
                  Albie325 Build Thread | Albie325 COTM Jan 2021
                  • Melon
                    • Mar 2018
                    • 1311
                    #324
                    As soon as I can!
                    Waiting on the shop to finish up my rear end.
                    I do things.
                    • Melon
                      • Mar 2018
                      • 1311
                      #325
                      UUC BBK
                      It's not bad, but if I were to do it again, I'd go with something from Massive Lee.
                      I do things.
                      • Melon
                        • Mar 2018
                        • 1311
                        #326
                        Finished for the weekend, got the vent window latches in, all grab handles and the washer nozzles on the hood. Skeet skeet!
                        I do things.
                        • Jokester
                          • Sep 2016
                          • 1818
                          #327
                          Please tell me you’re going to wet sand the car. Too much work has been done to leave a finish like that.
                          • Melon
                            • Mar 2018
                            • 1311
                            #328
                            I only put two coats of clear on it, and in some places it's a bit thin. I'm considering taking it to a professional detailer and seeing what they think, but I have no false hopes.
                            This was my first paint job, so lesson learned. Also, this car was always meant to be a driver, it was never meant to be a show queen.
                            I do things.
                            • majdomo
                              • Jun 2018
                              • 449
                              #329
                              As soon as I can!
                              Probably sorta important. :) Looking good, Louis!
                              • Melon
                                • Mar 2018
                                • 1311
                                #330
                                Got some photos from the shop, they had to do some work to get one half shaft out.
                                I do things.
