Melon's E30 Build.
  • Sonny
    • Feb 2019
    • 100
    #526
    I was just denied Hagerety?
    No ticket history
    10k value declared value , daily driven and 3,500k miles.
    • Pootis
      • 636
      #527
      Probably since you listed it as daily driven
      1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
      COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
      • Melon
        • Mar 2018
        • 1311
        #528
        I'm also 33.
        I do things.
        • 2mAn
          Señior Mod
          • 21017
          #529
          No ticket history
          because M10 with dented fender
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • Melon
            • Mar 2018
            • 1311
            #530
            Let it be known to all. Simon fucking keeps it real.
            I do things.
            • 2mAn
              Señior Mod
              • 21017
              #531
              about to get sig'd again my friend
              edit: just to sort of stay on topic... I have hagerty on my Datsun with a $15k value, probably upping it to $20k on my next renewal. E30 is under Allstate with the wifes POSUV
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              • Melon
                • Mar 2018
                • 1311
                #532
                Allstate is pretty good, that and State farm seem to offer the best coverage, best service and customer care.
                The Datsun is awesome man, love it.
                I do things.
                • Melon
                  • Mar 2018
                  • 1311
                  #533
                  Rebled the brakes, they feel great now.
                  ABS still isn't working, replaced all the hardware, so it has to be somewhere in the wiring.
                  I do things.
                  • Melon
                    • Mar 2018
                    • 1311
                    #534
                    I spoke too soon.
                    Driving down the interstate, boom, hard pull to the left. But, I can feel the ABS module pulsing through the pedal. That's new.
                    So something is giving the ABS module, or computer bad information. Possibly a sensor, or something, again, has to be in the wiring.
                    I do things.
                    • Albie325
                      • Jul 2016
                      • 515
                      #535
                      Damn, fingers crossed you get the brakes sorted. Mine gave me fits before the overhaul. Can't remember if you've tried the ABS relays as a possible issue?
                      '86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
                      Albie325 Build Thread | Albie325 COTM Jan 2021
                      • Sonny
                        • Feb 2019
                        • 100
                        #536
                        Melon's E30 Build.
                        I don’t have abs but did you torque down everything correctly? Perhaps reservoir Has dirty fluid . Mine is driving me crazy I feel a light clacking on drivers side. Just did hub replacement. When I press the brakes it stops but when I let go it’s a rhythmic clacking, I’ll let you know what I figure out and try to help
                        • Melon
                          • Mar 2018
                          • 1311
                          #537
                          Yeah, I cycled the pump when I bled them too.
                          I pulled the under-dash relay. Cutting the power solves the issue. It just doesn't have ABS, drive great tho.
                          I bled the while system from dry, so it's got nothing but brand new Ate200 fluid. I've been checking all the bolts periodically. Your clacking might be a warped rotor, or a pad sticking.
                          Also, the transmission is leaking fluid pretty regularly. I'll top it off before the trip, but I might need to pull it and send it off the have all the seals replaced.
                          I replaced them, and it appears to be the vent and shift selector seal. I've replaced that damn selector seal three times, with the last time shoving two in there, with the other edges coated in Curil K2.
                          I do things.
                          • Sonny
                            • Feb 2019
                            • 100
                            #538
                            Melon's E30 Build.
                            Are you using redline MTL? The PO of my car took it to a shop that filled her with regular easily leaking ATF.
                            • Melon
                              • Mar 2018
                              • 1311
                              #539
                              I used Redline in all my transmissions and differentials, unless specified by the manufacturer.
                              Getrag 260 Redline MTL GL-4 75w80
                              I do things.
                              • Melon
                                • Mar 2018
                                • 1311
                                #540
                                Getting ready to take the E30 on her first trip to TN.
                                I'm beyond excited for this. Hitting the mountain roads us exactly what I built this car for, and after over a year of hard work, I'm finally going to put it through it's paces and drive it like it was always meant to be driven. Pics will definitely be posted.
                                I do things.
