S14b23 Drivetrain overhaul and concours restoration.
  • efficient
    • Feb 2012
    • 3312
    #106
    updates?
    • Jordan
      • 12916
      #107
      Waiting on the cylinder head to come back from the machine shop... because surprise surprise they failed on their commitment to have it done for me Friday so I could finish building the engine this past weekend.
      Hopefully I'll have it this week.
      https://mtechniqueabs.com/
      • AWDBOB
        hooptie connoisseur
        • Aug 2013
        • 4507
        #108
        What was your process for installing the freeze plugs? I need to do them on my S14 in the near future.
        • Jordan
          • 12916
          #109
          Coat the flange with hylomar, line up with opening, hammer them in with a form fitting socket which was a deep well 24mm if I recall.
          Getting them out was much more difficult.
          • Jordan
            • 12916
            #110
            The cylinder head finally came back from the machine shop yesterday, and with that means a productive weekend.
            Headgasket in place
            Head set in place, bolts torqued.
            Cam tray set in place, torqued down.
            Camshafts installed, engine timed.
            Once the engine was timed I started measuring the valve lash, oh what a joy this was. All of the original shims were far too thick now so I ground one down until it fell into the correct range for adjustment and then checked it against all of the intake valves. Once done and recorded I moved to the exhaust side and then did it again.
            All of the original shims were in the 3.65mm - 3.80mm range. I ground one down to 3.45mm and then to 3.25mm to be able to take measurements at each lobe, both of which will be discarded.
            The table used to determine the optimal shims to order and keep track of where they need to go once they come in. Target lash is .026-.031mm.
            If anyone wants the active spreadsheet you can download it here: https://www.e30gruppe.com/wp-content...ent_m3guru.xls
            While I wait for the shims I can continue to assemble everything else as its easy enough to drop the shims in with just the valve cover loose.
            • parkerbink
              • Jun 2004
              • 10138
              #111
              As always just amazing work!
              • Andrew325is
                • Jan 2008
                • 1212
                #112
                That is one gorgeous engine.
                Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
                • econti
                  • May 2014
                  • 1152
                  #113
                  Stunning. A shame to put it in a car and not on a stand
                  • iXguido
                    • Nov 2009
                    • 730
                    #114
                    How does a person keep the bare aluminum parts looking fresh?
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      #115
                      There are products to apply to aluminum that will keep it from oxidizing over time. I've never used them, so I don't know how well it would work. Clear coat would likely be a cheaper/easier way, but is viable for many surfaces. Really you just have to accept that it will eventually oxidize.
                      • 0-60Motorsports
                        • 65
                        #116
                        Amazing build! Very informative. Thanks for posting the build. The owner is one lucky guy.
                        • D.Martijn
                          • Sep 2016
                          • 1024
                          #117
                          I've had good luck with covering my bead blasted intake, valve cover etc with a quartz coating. Still looks great after a cold/humid winter :)
                          1990 325iX Touring - November 2018 R3V Car Of The Month
                          1980 Volkswagen Golf mk1 1.1
                          1974 BMW 2002 Touring
                          Instagram
                          • bmwman91
                            • Oct 2004
                            • 3134
                            #118
                            Awesome work. The attention to detail is incredible.
                            Transaction Feedback: LINK
                            • Jordan
                              • 12916
                              #119
                              Alright, this will likely be the past photo update in this thread as I've wrapped up the engine for all intents and purposes.
                              Measured for valve adjustments needed and ordered 16 new shims, installed and buttoned up the valve cover. Its ready to go off to its owner and get installed in his super clean M3!
                              • TeXJ
                                • 1914
                                #120
                                im not seeing any photos
                                edit: work must be blocking these for some reason. I can see the photos from earlier posts in this thread...rip work
                                1990 325is
                                m52b28
                                3.73lsd
                                g260 (1987 325is 5spd tranny)
